Took the old girl for a decent drive up the coast this arvo and took some happy snaps with the iphone' date=' thought it was as good a reason to throw up a showcase as any.
I've had the car 6 years or so, a 1992 R32 GTR imported fresh from Japan, brought over with nothing more than catback, rims, pods and 80thou on the clock.
Here it is when I first got it...
[img']http://i71.photobucket.com/albums/i123/infamous_t/32R/636-DSC_0051.jpg[/img]
Anyway... I enjoyed it like that for some time, daily driven +400km a week, probably put 70K on the odo in the last few years.
Then about a year ago had a small accident, I didn't need the car for work any more, so it became a catalyst to take the car off the road and do more on the car.
Replacing bits here and there, completely removing others gets us to today
Engine
R34 GTR Factory Turbos
Splitfires
GReddy cooler piping
KTS intake piping
Mines Front Pipe
Trust Titanium Catback
"Highflow" cat
Blitz DSBC
Nistune
JJ catch can
Tomei adjustable cam gears
Handling/Braking
HSD HR Adjustable Coilovers
DBA 4000s
Braided clutch lines
Nismo GB + engine mounts
Whiteline adjustable swaybars front & rear
Strut braces front & rear (Cusco / Whiteline)
UAS upper control arms
Whiteline Rear Toe/Camber adjustable kits
Cusco Brake Stopper
Cusco Tension Rods
Midori HICAS Elimination arms... rest of HICAS shit goneeeeee
Drivetrain & Transmission
Nismo Coppermix Twinplate + braided line and upgraded pivot
S14 clutch master + adaptor
Interior
320km/hr Speedo
R34 GTR V-Spec / Carbing aluminium pedals
Nismo floor mats & gear knob
Exterior
Nismo LMGT4 18x9.5 +12 (Direzza Sport Z1 Star Spec 265/35R18)
Nismo lugs
N1 headlights
N1 front bar
N1 copy sideskirts
Trust copy pods
Smoked indicators
Nismo style CF Intercooler Duct
HIDs
Rolled guards front & rear, modified front liners
Currently makes 375awhp @ 16psi
Goes pretty well, but I have some poncams to go in and looking to change to a midsized single turbo and MAP based ecu early next year.
If all goes well there's hopefully a decent brake upgrade on the horizon after that, but one thing at a time for now...
https://www.sau.com.au/forums/topic/411603-ts-r32-gtr/
  • 1 month later...
  • 3 months later...
  • 4 weeks later...
Let us know if that shaft give you any vibrations! Most carbon shafts do unfortunately
Can only be less than the amount of vibrations I'm currently getting LOL
It's a strange thing, some people report problem, some don't.
Not sure if it's brand specific thing (ACPT group buy dramas comes to mind), or other problems resonating though, or simply that you just need to spend a little extra time doing things like shimming up gearbox mounts to get the tailshaft angle perfect.
Find out soon enough I guess :)
https://www.sau.com.au/forums/topic/411603-ts-r32-gtr/#findComment-6835667
  • 3 weeks later...
Thicker/higher grade wiring than stock, around the same price as a replacement OEM harness, ~$200.
This version (there's 2) also has direct wiring/earth back to the battery.
Should hopefully equate to a stronger, more reliable spark... e85 ready :)
https://www.sau.com.au/forums/topic/411603-ts-r32-gtr/#findComment-6858567
  • 2 months later...
So I got the car back today, to say the car drives very well is an understatement :D
The guts of the work I needed done was to get the car driving well before looking at power upgrades later in the year.
Wheel bearings, rear diff, tailshaft were all changed up for new items, while the subframe was removed for some restoration...
The Nismo 1.5 way diff was sent off with the old diff to get sorted, the subframe was dropped for powdercoating and fresh bushes all round.
Now I'd always suspected my subframe was a little bit special needs, but when it was dropped it was best compared to my favourite yellow fruit.. the banana.
So a replacement straight subframe was obtained... some stripping, sandblasting, powdercoating then sent off for rebushing and some basic alignment settings, finished product had this baby looking brand new.
1080905_10153102289600076_1421468217_n_z
1167802_10153102289640076_540563676_n_zp
Had a comp test done... which came up fairly good, happy considering its a +160K RB26.
So now I know the motor is still healthy, the car drives straight & well, no random vibrations (just the good ones), and it will put the power down nicely.
From here it's time to let my hip pocket recover for a little bit and enjoy driving the car again, then I'll focus my attention to some power increases, which the plan is now for Vipec + -5s + poncams + e85
https://www.sau.com.au/forums/topic/411603-ts-r32-gtr/#findComment-6976050
  • 1 year later...
Figured a bit of an update was in order...
Sent the GTR in to get the Galvsport touch towards the end of 2014, basics are:
Garret -5s twins with all hot side pipe work ceramic coated (ported ex. manifolds, mines dumps & front pipe)
Tomei Poncam Bs (260 / 260 @ 9.15mm)
GReddy intake kit, but with K&N pods with custom joining pipework to get it sitting in a good spot.
Vipec plug + flex fuel sensor + ecu controlled boost solenoid
Walbro e85 fuel pump + ASNU 1100cc injectors + Nismo FPR
Galvsport signature airconditioning restoration!
Misc servicing and replacement of perished OEM hoses & wiring
I've had the car back about 3 weeks now (thanks for opening up over xmas break Josh!) and it drives amazingly... certainly has renewed my love for the car!
Aircon makes immensely more enjoyable to drive on hot days!
With no noticeable loss in response from 34R+dialed in stock cams, but power band pushing well past were the old setup fell over, coming through corners I find I'm in the sweet spot of the powerband.
As I said to Josh after the first proper drive "f**k she's quick!"
Although the 98 tune is complete, the car still needs to go back in for a day to finish of the flex tune... something that couldn't be avoided due to xmas shutdown without being without the car a further 4-6 weeks.
This also means there is more to come, which greatly excites me!
I'm currently trying to touch up the car where she's got a bit rough over the years, fixing up interior further and cleaning up the engine bay with new bits and cleaning of the decades of grime.
I don't have any new photos or dyno charts at the moment, but as no one likes walls of text, here's another pic from the Galvsport Barbagello Track day.
https://www.sau.com.au/forums/topic/411603-ts-r32-gtr/#findComment-7461884
Greddy intake pipe work, thinking about redoing them with black joiners and black coated pipe work.
A relocated PS res to free up some room might be the go down the track.
80A9908C-387F-450F-893E-C4FBF8873282_zps
Flex sensor and some sexy fittings hiding behind oil filter
60B126D5-4A1D-443E-AC78-D08A5F320F26_zps
Planning on doing a boot mounted reservoir, once done I can get both pods nestled low near the bumper feed, but setup works perfect for now.
You can also see the colour difference between panels where I've managed to clear off the 20yrs of grime.
79375007-929F-4475-B89A-BB0CAD8DB2C4_zps
Loving the induction noise of the new turbos and intake setup, stock bovs make a bit of noise now too LOL
Also shows the garage defend air guide I installed a while back.
I'll get a proper catch can eventually!
29AEBB53-EB82-48C0-9E6B-02BD1F95B613_zps
https://www.sau.com.au/forums/topic/411603-ts-r32-gtr/#findComment-7461886
Absolutely beautiful mate, I'm after a set of N1 side skirts and Trust pods myself. Do you know what brand you got and if so how's the fittment? Cheers
Pods were 2nd hand off here so unsure... N1 side skirts were JSAI and the fitment was rubbish.
https://www.sau.com.au/forums/topic/411603-ts-r32-gtr/#findComment-7461887
    • Nah. Was just wondering if you were having a small stroke or if there was some slur/gaf/inside joke that I wasn't aware of.
    • That was a fark up, it's Salamanca Place I was thinking of. And now I'm curious as to what potential slur/gaf I have caused with Salamander Road, ha ha!
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
