are you using the ignitor module or are you earth the coils straight from the computer
There is no earth from the computer to the packs, the two wires from the computer are power and pulse the earth is on the packs. Where is the ignitor module located, I was led to believe that the LTX12 controlled all of that.
yes i know that there is not individual earths ect what i should have said was are you still using a nissan ignitor module or is the computer pulsing the coils for you????
The computer pulses the coils or is meant too, the thing is i have pulse up to the packs but no spark at the plugs, plugs are all fine, and I thought I may have wired somthing wrong somewhere.
The packs themselves have three wires earth, power and pulse the microtech LTX12 has one main power wire and individual pulse wires(one wire for each pack) but no earth. I have wired the earth to the body but to no avail and because it is an engine conversion can't look for ignitor, even though the comp is meant do all that.
Any and all ideas are welcome because I go home and try them all out.
found a diagram of the LTX12 wiring for the packs looks easy but nothing happens. Have to find way of posting it is to big.
is there an earth to the cradle that holds the coils thats also earths to the head, make sure thats there and try using the earth off the engine before using the body.... check your plugs casue if they are iridiums or anything the foul up easily and once they have been drowned ie sitting there trying to start the car they will be rooted for life they are a waste of money get some stockies and gap them down to .8mm....
Getting confusing, keep forgetting how my own computer works. There are the six wires for each individual pack (pulse) and two earth wires that join into one which was attached to the heads but i have moved to several other locations to no avail. I have even attached the earth from the packs to the computer earth, still nothing. I have tried to download the wiring diagram to the thread but it is to big, but you can check it out at, http://www.microtech-efi.com/downloads/65.pdf. Might give you some idea rather than my ranting.
is the rb25det a series 1 or series 2 motor??
series 1 have a igniter pack on the back or the coil cover .
series 2 motors have the igniter in the coils themself's or in the comp..
you may have to get a igniter pack or module to fire the coils..
It is a series 2 the computer is supposed to ignite the packs thats why I have the LTX12 microtech computer. you can see it at, http://www.microtech-efi.com/downloads/65.pdf if you wish.
Having a closer look at that diagram, I reckon those are direct-fire coils, not coilpacks.
Instead of having a coil that fires into a distributor which then directs the spark to the appropriate plug, these are coils that fire directly to the spark plug, via a plug lead ie no distributor required, but multiple coils required.
I'd get back to Microtech and ask them how to solve the problem.
Thanks Blind_elk, this is becoming an ever increasing nightmare, the projected budget has blown out of all proportion and simply can't afford to the car on the road all the help I get is very much appreciated.
Have been told to take the packs out and send them to microtech for testing, do you know how i can test them at home before i go to that expense.
Thats right the paks are attached to the plugs and are wired direct to cpu.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
