  • 3 weeks later...
New boost controller installed and it got its tuna. Running high and low boost settings.
235kw @ 8psi
290kw @ 16psi
Kept breaking traction at higher boost so will be adjusting the wheel alignment and bringing it back in for another run soon.
  • Like 1
Before wheel aligning I had to make some more room under the guards so prepped up the fibreglass guards which gave the front wheels plenty of room to move.
post-89239-0-20096900-1463271408_thumb.jpgpost-89239-0-04859400-1463271501_thumb.jpgpost-89239-0-56296100-1463271546_thumb.jpg
Painted them and then decided I hated them on the car. They ruined the lines and look rubbish.
So I went to town on the standard guards instead. I cut the inner lip off completely and then flared them out as much as possible. They're a bit rough but they work. Might smooth them off properly and paint them, or might just buy gtr guards we'll see.
  • Like 1
Flared/Pumped out the rear guards as well with the heat gun, baseball bat and phone book method. With a lot of patience it actually worked out really well, they're a lot more roomy. Then spent a couple of days with Heasmans getting straight.
Checked the plugs yesterday then spent a little more time on the dyno. It running nice and clean, still needs some work at higher boost but it's happy as a pig in mud at around 12psi. Drove it straight off the dyno and out to Eastern Creek for some drifts around the skid pan. Drove it hard all night and it behaved itself like a gentleman, then drove it home again afterward.
So good to get some wheel time without something breaking on this thing. It's been solid af lately. Should see some track time very soon
Thanks mate!!
I'm from Epping. Where are you from?
You'd have done well to have seen the car around Sydney it's spent almost 6 out of the 7 years I've owned it locked up in my garage. Last week was its first ever trip to the creek
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
