For sale - 1989 R32 skyline
Built rb26/30 by lewis engines in SA, 6boost manifold,
gt3582r turbo, 50mm turbo smart gate, vi-pec ecu and 25 gearbox
Tuned by Godzilla Motorsport in Brissy running about 380hp
Very safe tune
Quick car and very torquey car
Currently rego'd till jan next year but will be selling without roady
Much more done, car is set up for the track specifically drift any
question please call or text or message on here 0432470609
$15500 Ono I'm open to offers guys
Mainly after swaps maybe something BMW or euro maybe a v8
or something let me know what ya got, open to offers
feel free to ask questions im happy to answer
Edited by blockasR32
https://www.sau.com.au/forums/topic/412299-fs-r32-skyline-rb30det-26-head/
  • 5 months later...
Wouldnt consider a swap for a manual R34 GTT sedan? Here's a link to an ad for pictures etc. http://www.gumtree.com.au/c-ViewAd?AdId=1006047719
Cheers :)
  • 4 weeks later...
Nissan R32 Skyline 1989 GTS-T
Engine
currently tuned by godzilla motorsports in brisbane for 380hp @ 20psi
Lewis engines built 26/30
800cc injectors
Vi-pec ecu
6Boost manifold
GT3582R turbo 1.06a/r rear housing
turbosmart 50mm wastegate
3in intercooler piping
3 and a half inch dump pipe
3in exhaust with varex muffler
poly engine mounts
rb25 manual gearbox
jim berry rebuilt os gieken twin plate clutch
10000k's since engine conversion
one piece tail shaft
kazz 1.5way lsd
56mm radiator
4in intake pipe with k&n pod filter
recirculating custom catch can
viscos engine fan and 12 inch thermo
walbro 255l/h intank fuel pump
2.5l surge tank with bosch 044 external
will come with brand new JUN 272/9.7 lift cams and JUN valve springs for the right price
suspension
hsd coilovers all round
rear camber arms
rear toe arms
hicas lock bar
front castor arms
wheels
rota grid 18x10 all round +15 offset
interior
deep dish wheel
short shifter
5in tacho
bride copy lowmax driver seat
genuine bride seat rail
stripped rear seats and belts
sony head unit
kicker amp 350.4
kenwood 5x7 front speakers
jvc 6x9 rear speakers
exterior
matte black in colour
gtr bonnet
gtr front guards
gtr head lights with HID lights
smoked gtr indicators
smoked led tail lights
car is currently registered and has been mod plated for all mods in queensland
for any more info please feel free to give me a call or text on 0432470609
thanks for your time
cheers stephen
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
