For sale - 1989 R32 skyline
Built rb26/30 by lewis engines in SA, 6boost manifold,
gt3582r turbo, 50mm turbo smart gate, vi-pec ecu and 25 gearbox
Tuned by Godzilla Motorsport in Brissy running about 380hp
Very safe tune
Quick car and very torquey car
Currently rego'd till jan next year but will be selling without roady
Much more done, car is set up for the track specifically drift any
question please call or text or message on here 0432470609
$15500 Ono I'm open to offers guys
Mainly after swaps maybe something BMW or euro maybe a v8
or something let me know what ya got, open to offers
feel free to ask questions im happy to answer
Edited by blockasR32
https://www.sau.com.au/forums/topic/412299-fs-r32-skyline-rb30det-26-head/
  • 5 months later...
Wouldnt consider a swap for a manual R34 GTT sedan? Here's a link to an ad for pictures etc. http://www.gumtree.com.au/c-ViewAd?AdId=1006047719
Cheers :)
  • 4 weeks later...
Nissan R32 Skyline 1989 GTS-T
Engine
currently tuned by godzilla motorsports in brisbane for 380hp @ 20psi
Lewis engines built 26/30
800cc injectors
Vi-pec ecu
6Boost manifold
GT3582R turbo 1.06a/r rear housing
turbosmart 50mm wastegate
3in intercooler piping
3 and a half inch dump pipe
3in exhaust with varex muffler
poly engine mounts
rb25 manual gearbox
jim berry rebuilt os gieken twin plate clutch
10000k's since engine conversion
one piece tail shaft
kazz 1.5way lsd
56mm radiator
4in intake pipe with k&n pod filter
recirculating custom catch can
viscos engine fan and 12 inch thermo
walbro 255l/h intank fuel pump
2.5l surge tank with bosch 044 external
will come with brand new JUN 272/9.7 lift cams and JUN valve springs for the right price
suspension
hsd coilovers all round
rear camber arms
rear toe arms
hicas lock bar
front castor arms
wheels
rota grid 18x10 all round +15 offset
interior
deep dish wheel
short shifter
5in tacho
bride copy lowmax driver seat
genuine bride seat rail
stripped rear seats and belts
sony head unit
kicker amp 350.4
kenwood 5x7 front speakers
jvc 6x9 rear speakers
exterior
matte black in colour
gtr bonnet
gtr front guards
gtr head lights with HID lights
smoked gtr indicators
smoked led tail lights
car is currently registered and has been mod plated for all mods in queensland
for any more info please feel free to give me a call or text on 0432470609
thanks for your time
cheers stephen
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
