Before we start, this modification is ENTIRELY AT YOUR OWN RISK and is here purely for the benefit of others, I am in no way claiming it to be safe, reliable or a good idea.
In brief, my HICAS has given me the s**** ever since i bought the car about three years ago, weekly the light came on due to the aftermarket steering wheel the car came with, I pulled the globe out the dash and this worked for months, then the power steering dropped out intermittently, which I got around by re-wiring the HICAS ECU to reset on key-off, and then finally in the last few weeks I hardly had power steering at all. Why not just fix it? Because everyone seems to have trouble eventually and it keeps happening over and over.
If people need I can provide pictures, but the process is relatively simple. I wouldn't recommend doing this if you aren't confident or %100 sure of what you're doing. But this is the cheapest, quickest, most effective fix i've found thus far.
After some digging, I found a way to disable HICAS all-together, and keep the power steering functional. This is for R33 Series 1 NON abs, but may suit others
1. Locate the HICAS ECU under the parcel shelf, unplug the big fat connector at the back.
2. Face the connector towards you as if YOU are the HICAS ECU pins, as this is how the diagram below is read.
3. Observe this diagram: http://www.skylineowners.com/forum/attachment.php?attachmentid=47736&d=1286623689 courtesy of the Skyline owners forum.
Note pins 14 and 5, 14 is 10amp switched power from the ignition, pin 5 is the HICAS ECU signal output to the power steering rack solenoid valve, the ECU uses this wire to give speed proportional power steering.
This next part is up to you, but pins 14 and 5 need to be bridged, personally I recommend cutting and soldering the wires directly together then heat-shrinking to avoid any complications.
FROM MEMORY ONLY, the wire to pin 14 was green with a black trace, and the wire to pin 5 was pink, these two wires need to be used to avoid powering the solenoid with the key off and draining the battery.
This then supplies constant power to the solenoid valve, giving %100 power steering at all speeds (read further down for more information).
4. Leave the HICAS ECU disconnected, as I doubt it will like having 12volt power plumbed back into a signal output, and it's no longer needed anyway.
5. You can now fit a HICAS lock bar without the complication of losing power steering, and disconnect any HICAS related sensors and components with no other side-effects, so long as the wiring from the solenoid valve and switched ignition remains in-tact. I doubt the light will come on, but if it does remove the globe from the dash is the best way around this.
6. Take the car for a drive, but be aware that the steering will be much lighter at high speeds. Be cautious on the first drive as the steering will be much more direct and "twitchier".
Will/can this modification damage my car?
Honestly, i'm yet to find out. I literally did this mod tonight after weeks of frustration and research. The power steering pump could fail, the solenoid valve may burn out, the 10 amps from the ignition fuse may not be enough to run the solenoid long-term, or any other number of nasty things, but once i've driven the car for a while I will report back here if there are any ill-effects.
At the moment the only difference i've noticed on a 10-15 minute test drive is the steering being 15-25% lighter above 80km/h, and also it works on 100% of drives rather than the 10% before.
Can I revert back to HICAS?
Very easily, simply de-bridge the connection between pins 5 and 14, and re-connect the ECU, things will now go back to normal.
Cheers, Josh
  • Like 1
Only been on for a week, but done roughly 500km including a few runs at the drags. So far no problems at all, just enjoying my power steering working every time I drive the car!
  • 4 weeks later...
My car doesn't have ABS, and apparently the HICAS ECU is different between ABS and non ABS models, so i'd assume the pin-outs would be different too. They could be the same, but I know that this particular mod works on this exact model GTS/GTST.....
  • 4 weeks later...
Mine wasn't for some reason. If I removed the HICAS ECU the steering went heavy and stayed that way, I assume as there was nothing powering the rack valve and it couldn't get pressure.....
  • 4 weeks later...
My HICAS lock bar is fitted on my ABS S1 , leaving the Hicas Computer connected in the boot its not my HICAS light that is on, its my ABS light ?
Once i'd figured out how to get the power steering to work without the HICAS ECU I saw no point in leaving it in so it now resides in a box with the rest of the stock parts.... As above the non abs and abs hicas ECU's apparently differ so if the hicas acts up it may upset the abs.
  • 1 month later...
  • 1 month later...
my r33 has a whiny power steering pump and when turning jerks alil do u think doing this will help or is my pump stuffed ? im a new skyline owner and dont know alot about them so any advice would b very helpful :)
  • 7 months later...
It ended up being the pump i think from memory I changed it and the power steering worked fine again. I'm rebuilding the car again at the moment and putting in a cage so I'll be removing the hicas computer all together so I'll let everyone know if it plays up but I'm also running microtech so I don't think tgere will be a prob
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
