Easy to source, nice and cheap: what's not to like?
I have also been in regular contact with another Y34 owner who has successfully sourced (Maxima?) brake pads, and shimmed them to fit our cars: will post part numbers when I get them...
Also, just FYI: not sure if it's a common issue (I haven't experienced it), but he had ongoing, intermittent rough-running issues, which after much diagnosis turned out to be failing ignition coils.
Just a couple of things to bear in mind: once we get enough info, it may be a good idea to create a Y34 parts/service sticky thread, as there's precious little information available on the interwebs...
Yeah i agree - i've found there's really not much info available on there however Aus-Vip.com i have found has a little.. not much.. but a little haha. I have the same intermittent rough-running issues but i had put it down to coilpacks as it seems to be the same sort of issue as what I had years ago in an S13 then replaced the coilpacks and all fixed.
I havn't bothered to buy new coilpacks yet for my Y34 but was planning on getting a set of Yellow Jackets from performance-wise.
Also I had my radiator end tanks replaced which turned out to be the same/very similar to Navara radiator end tanks so they were used :)
And when i needed new brake pads I took the worn out pads to SA Brake & Clutch and they matched them up with some replacements - no modification was needed either.
yeah: the brake pad thing seemed a little odd to me: I figure I'll be able to source a set of Endless or similar quite easily. Will do some research to ascertain whether ours are the same as the USDM M45- I'd say it's a pretty safe bet. Also, have seen a number of Y34s going at auction with what I believe to be CPV35 Brembos fitted, so it may be that we run the same brakes as a non-brembo V35, given Mr. Nissan's tendency to use interchangeable parts.... Once again: more research required.
For anyone looking for more info on part compatibility for Y34's (servicing, etc) see this thread: http://aus-vip.com/topic/2778-y34-gloriacedric-maintenance-info-part-number-listing/
  • 1 month later...
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
