7 hours ago, Glorius said:
GDay I have a y34 here in Christchurch NZ , and also would like an English manual for the dash settings , cheers [email protected]
Sweet bro
  • 2 months later...
  • 2 months later...
  • 2 months later...
7 hours ago, NismoCedric said:
Friends someone please send a copy of the manual , can not start the engine 30det. Need help )) my mail - [email protected]
ill send it now.
Its not a manual, it wont help you with mechanical issues.
  • Like 1
10 hours ago, Leroy Peterson said:
ill send it now.
not correctly read =) And is there any information on ECU schemes and pinouts? Thanks for the translation of the menu, it was very useful!)
On eBay found a user manual for the 34 cedric and gloria, you need to ask the seller if there are schemes and pinouts there
Edited by NismoCedric
Start a new thread and tell us what problems you're having and see if we can assist.
Never checked, but assumed ECU pin out is the same as NM35
  • 1 month later...
  • 6 months later...
  • 1 month later...
Hello ,
I just bought the y34 and need help to know about the car but everything is in Japanese which i can't read,
Can someone email me a translated manual, it will be very useful to me. Thanks in advance :D
[email protected]
  • 3 months later...
  • 2 months later...
  • 3 months later...
  • 1 month later...
  • 7 months later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
