So im new here, and to Skylines in general.
Not sure if this the right section, but here goes.
Quick run down on car,
1993 S2 R33
RB25DET manual
Pod Filter
3" cat back exhaust
rest is stock.
Problem is.
its very hard to start first thing of the day, sorta like a carby car you gotta hold the throttle while cranking. once it kicks in the revs will jump to around 1200 till warm. rest of day its 1 crank start.. weird.
Once warm the idle drops to 900, all seems sweet. Till you touch the throttle slightly, the revs drop and you can actually make the car stall by doing this. press throttle slightly more and it will spring to life, sorta feels like a flat spot from 900-1000?. if you give it a slight rev to say 3-4k and back off the revs will drop to 500ish and then bounce back too 900 and hunt around the 750-950 mark. couple small revs to "clear it out" and she idles fine at 900.
Now before this the idle was hunting around the 500-900 mark, i pulled the ACC assembly out as per the DIY on here. cleaned it all, followed the idle reset guide and waaam, the idle is great at a solid 900. but then it came back :(
Im at a loss to what to check next? im thinking give the AFM a clean as per the guide on here,
Also curious if coil packs will cause such a issue?
Any help is appreciated, or links, guides, directions ect.
Dan
https://www.sau.com.au/forums/topic/412719-weird-idle-hard-to-start-when-cold/
Catch can has been bought, ive noticed a little oil in intake and pipes for cooler.
I was thinking when its sitting there idle a little oil gets in, got to hit the gas and the oil has cover plugs slightly? is that possible?
On a weird note, turning the AC on removes this issue though it only bumps idle to 1050ish. enough to pass "flat spot".. its how ive been driving ATM otherwise it feels like it will conk out, or splutter when i go to take off.
will the AFM cause the bad cold start? im assuming not
cleaned the AFM, installed catch can and a FMIC.
runs soooo much better now. still after a big rev idle will drop to 500 and bounce back to 900 and sit there.
cold starts still a hassle, time to clean the cold start valve thingy under manifold???
AAC auxiliary air control, is the one under the plenum.. used for cold starts etc.. and has that hose connected to the crossover pipe
IAV Idle some valve is the one attached to the side of the plenum, used for idle
  • 3 weeks later...
Still hard to start in morning,
i have to attempt to start it 4-5 times, then a little pedal work to get it to actually start. then it will hover at 500rpm for 2-3 seconds, then cold valve kicks in and bam, 1800rpm for warm up.
Idle is perfect now,
If your car starts fine in the cold with the pedal pressed a little, it seems like your AAC (under the plenum) is playing up. The IAV only controls idle NOT high idle for cold starts.
You say stock, but you don't have an aftermarket BOV do you?
Sounds like a couple of problems.
1 - Slight leak in the vacuum lines (remove each line from the plenum during fast idle and if removing one doesn't make a difference then it's probably leaking).
2 - Get some upper engine cleaner (Nulon). Follow the directions on the can. But you don't need to bother with the squirting into the pistons, etc. Just clean the plenum and AAC/IAV.
HINT use a fast idle for both of the above ~1200rpm: Get a folded piece of paper or business card and use it as a slight spacer ~2mm on the throttle body. (Between the throttle stop and the accelerator cable). Gives you a nice fast idle ~1200rpm.
Edited by simpletool
Yeah stock BOV mate, it makes a noise why replace it? haha
Yeah i may just get some vacuum line and replace what i can anyway.
How do i go about getting the AAC off from under the plenum? not much room to work around.
get a small 1/4" socket set and an uni-joint.. you'll manage, after some beers and loads of swearing :)
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
