Blue R33 with a dodgy R34 front end conversion? I used to see it around every now and again in Hobart when it was still registered a few years back, I thought it looked awesome when I first saw it but on closer inspection it looks like it was a little bit roughly put together (never saw in too much detail though). The guy who owned it at the time drove it like the king of douche bags. Only general douche baggery in traffic and throwing it around, seemed to like the image, never saw him sitting on limiter or anything like that though.
From memory when I was initially praising the cars looks Funz32 didn't seem to think much of it, I don't know how much experience he had with the car but he knew the driver by name (daniel? I think?), could be worth asking him :)
A lot of people from here should know the car because it stands out like a sore thumb, good luck mate
Found it, even has pics of how it was in January 2010. Reading my posts it seems I have a pretty different opinion of the car and driver, maybe time has made me into an arsehole?
Either way, this is the post I was looking for:
has been in a severe front end, not sure of how much damage came out of it though, but a bit. as for the rest.. umm yeah.. no comment :)
Here's the rest of the thread for context:
http://www.skylinesaustralia.com/forums/topic/152949-tassie-spotto/page__st__540
cheers guys, the few times i saw it, it was pretty haggard too, but now seems to have had some $$ spent on it as its all one colour and looked straight? only thing that put me off was the fact it is unrego'd and needs pitting and still asking 8k...
iv been informed its rb25de+t with a 20 box? can anyone confirm this?
yes i know that car , it's definitely de+t , still 4 stud last time i saw it , has definitely had a hard life by the people i saw that owned it . all of the body kit was sikaflexed on and painted over , the best part about the car was the new head lights . it may be better than it was when i last saw it though .
*shameless plug* i have a nice 32 sedan id sell around that money , nice tidy car :)
Left hand rear quarter has about 50 pounds of bog in in it, looks Like it was applied with a shovel and rubbed with a rock. Hands down one of the biggest shitters about. Was "clean" about 6 years ago, would make good target practice now.
wasnt really looking for a tidy daily all the same as i have my 32 and a bmw, but still.. i turned away from it lol.
he's asking 8k needing pitting.. (dreaming i know but i planned to lowball him and use facts against him lol)
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
