Deca Accommodation - Fri 7Th / Sat 8Th December
Where: Courtyard Motor Inn
Address: 58 - 60 Wyndham St, Shepparton VIC 3630
When: Fri 7th & Sat 8th December
I've reserved the entire hotel.
You need to let me know ASAP which room you would like booked.
We are going to Taco Bills for finger food and margharitas on Saturday night from 7.30pm.
Rooms Left:-
Sat night only - Deluxe Queen w/ Spa Bath $95
(as always - priority goes to people staying both nights, unless I can do a clean swap)
If this hotel books out, I've got 2 other options directly across the road for extras as well!!!
http://wyndhamere.bestwestern.com.au/
03 5821 3088
OR
http://tudorhousemotorinn.com.au/
(03) 5821 8411
  • Replies 46
People I have booked rooms BOTH NIGHTS for:-
Leon & Dean
Russell & Femino, Tim, Mark
Wayne
Sean & Joey
Scotland
Ryan
Bec
Justine
Mick
Paul & Kat
Campbell & Laura
Kieran & Robbie Williams
Jake
Laith
Leigh G + 2
Collins
Aaron Tan + 1!!! :)
Jett + 1
Snowy
Jarrod
Newton
Fri Only
Ash - Qu + bunks
Tim W
Sat Only
Jacqui - Qu + bunks
pussies!!!
lol Karina (Jack's mrs) will be over 8 months pregnant by then - The balls it took to ask for a leave pass for just that one night is something to behold :laugh:
If we could stay longer - I would this time f0 sh0!
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
