Hey guys, just got a problem hoping someone can help me with it or point me in the right direction to get it fixed.
I have a rb20 with a turbo from hypergear, nistune ecu, injectors, front mount, full exhaust all the usual mods, when i rev it out from 1st gear to second gear in high rpm it bogs down/lag and then the power kicks back in once ur in second gear, its almost feels like u slam on the brakes inbetween the gear change. Uts getting really annoying and i dont know what it could be, i thought it could be the BOV, coz i had it blocked off so i thought it might have been the air going back out the turbo slowing the wheel down but unblocked it and it still does it, i also have the pipe that comes off the BOV just pointing into the engine bay, not back into the intake, its still a stock BOV aswell.
If anyone could help me out that would be much appreciated.
https://www.sau.com.au/forums/topic/412962-rb20-lag-bog-down-high-rpm/
Do you mean where the plumb back pipe connects into the intake pipe, it's not connected?
So you are sucking air into the turbo through the hole in the side of the intake pipe?
Air that is unfiltered and also not measured by the AFM?
This would be a problem me thinks...
The Bov plumb back pipe, it's not attached to the Bov right?
Is the other end still attached to the intake pipe between the AFM and the Turbo?
Have you blocked any of the open pipes?
Its just the normal stock BOV and the pipe that from the trumpet bit of it just goes to no where to the engine bay, it used to go to some pipe which took it back to the intake for the emision reasons, but since upgrading to another turbo i had to get rid of all that so that bit of pipe just vents to the engine bay, and no other pipes have been blocked either
Blame the tuner :P
Waiting on NIStunes reply. They emailed today. Hopefuly have a few answers tomorrow
send it through if you need a quick reply, have the tuning lappy at home tonight.
I also had this problem on the R33, happens the air doses backwards onto the AFM. It was fixed by relocating the afm into the cooler piping.
Definatey seems like the same issue, and to clear things up its not a lag issue, its a hesitation
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
