Hey All Just would like to reach out to the SAU community and see what happens
on Saturday morning at 2:55 am my partners R34 4 Door grey non turbo auto was stolen from the drive way in Albert park
This car is very distinctive as it has a sunroof and the 2 front guards have dents and scratches from a light crash and have been
panel beated out (quick job) also it has 16 inc silver mags just 6 spoke stock looking things also last week remover the rear spoiler and put in rubber grommets so there is no mistaking this car
A unconfirmed sighting has been at klemzik and hecktervile but not sure due to the fact that the person that stole it was on a push
bike and left it out the front
Any quick sightings or leads would be much appreciated thank you to all this is a family car as we have 2 kids and was just a daily
for my partner and the kids
0421591550
https://www.sau.com.au/forums/topic/413012-stolen-r34-4-door-grey-sunroof/
  • Replies 40
as we were driving the streets wooooooohhhhhh speeds past the skyline as we pursued in a excel a cop started the chace 17 mins and 20 cops later he mounted a gutter blew the tyre and cops got him damage is bumper snapped off and probs suspension
I keep tell you all that the justice system in this state is f**ked.
Good to hear that there was not a lot of damage done to the car. Always heartbreaking to hear of a nice car being stolen,
Maybe they cant prove that person actually broke and entered / stole the vehicle - only caught "with illegal use of a motor vehicle, aggravated driving dangerously to evade police and providing false details"
Hey got refused bail because he broke prior bail conditions ( go figure ) and can't prove it because a key was used for the car
And more damage than first told
Front rh steering rod
Front lower control arm both bent bad
Need new wheels
He side swiped a car needs new head lights
Amazingly the front bar is fine other than scratches so if anyone has any of those parts plz contact me cheers
Also I saw the vid or a petrol run he did 6 hrs prior to the chase and he seemed quite uncomfortable and lost really 40 bucks and gee was he all over the shop
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
