  • Replies 54
I had mine for a few months and blew the oil pump. That was in April. I still don't have the car back yet. Cooked the pistons, bearings, cracked the block, blew the turbos, clutch and 4th gear. And the pump came out in seven pieces Found out then that the thermostat was shot, the harmonic balancer had been welded on and that an RB26 is the hardest engine to work on. Then got taken for a ride by the mechinist..... But almost done! :)
Solid effort. Mine blew the head cracked a few pistons and shattered some valves. All in All the work was to bore the block out slightly, new pistons and rods and a complete head rebuild. On top of that We did a full fuel system upgrade including a new oil pump... the only things that i DIDN'T touch as im broke where the injectors (that we where told are fine) the ECU and the turbos. ECU is getting done ASAP. And now i blew a turbo.... So both of those are getting replaced. Fingers crossed nothing else dies. Like i said with a triple plate clutch and a 33 gearbox lets hope not.... But man that's a solid effort on that 26 you did. Hope you get yours back all nice with no issues!
Yep a heavy part of my cost was rebuilding the block/head. Fingers crossed you get it back all sweet! i was wishing to bring the 32 to the SAU event this week. But unless i get the fastest Turbo replacement in history i doubt it hahaha.
hahaha MOAR POWAH=Future issues... Wait for it all to start... How much you aiming for? Im expecting mine to be close to 300KW and that's ill i really want in a road car haha.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
