hey guys my gtr 32 is due for a brake service i have standard bakes all round on my r 32 gtr. pads are pretty worn down im unsure on what pads are in it. car is making close to 500 hp at 4.
are the standard drilled rotors ok to use again can you get them machined? and i am wanting to know what good pads i can put back in the car is a street car mainly might do a little track in the future.
I would ditch the drilled rotors and start off with a fresh set.
Cross Drilled rotors have less surface braking area and slight cracks will appear around the hole areas after many years.
Depends on how worn the rotors are, but if they are very worn, you can't machine them as they will get too thin.
DBA / Project Mu make good replacements for brake and rotor setups.
At the moment I run DBA 4000 rotors with Project Mu B Spec pads.
Quite good on price too.
Drilled rotors can crack, but if they're not cracked now and have plenty of meat left in them you may as well use them again. IIRC the rotors are 32mm wide new and 30mm is the wear limit. I never machine rotors at a pad change unless there's a problem with them.
whats the best pads to use if the discs have heaps of meat left and arnt cracked.
ps they have been working fine just getting low on pads but there is slight groves in discs etc
Depends on how you drive, and if you do any track days.
If you want a pad that can cope with a track day but not be too much for the street QFM A1RMs are great and cheap. If you're street only, then something milder than and A1RM should have better grip cold, and be kinder to the rotors. I've used EBC greens and they were great, but these days i'd probably try QFM HPX or the Remsas (See trader GSL Rallysport for both - also he can recommend a pad based on your usage).
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
