hey guys my gtr 32 is due for a brake service i have standard bakes all round on my r 32 gtr. pads are pretty worn down im unsure on what pads are in it. car is making close to 500 hp at 4.
are the standard drilled rotors ok to use again can you get them machined? and i am wanting to know what good pads i can put back in the car is a street car mainly might do a little track in the future.
I would ditch the drilled rotors and start off with a fresh set.
Cross Drilled rotors have less surface braking area and slight cracks will appear around the hole areas after many years.
Depends on how worn the rotors are, but if they are very worn, you can't machine them as they will get too thin.
DBA / Project Mu make good replacements for brake and rotor setups.
At the moment I run DBA 4000 rotors with Project Mu B Spec pads.
Quite good on price too.
Drilled rotors can crack, but if they're not cracked now and have plenty of meat left in them you may as well use them again. IIRC the rotors are 32mm wide new and 30mm is the wear limit. I never machine rotors at a pad change unless there's a problem with them.
whats the best pads to use if the discs have heaps of meat left and arnt cracked.
ps they have been working fine just getting low on pads but there is slight groves in discs etc
Depends on how you drive, and if you do any track days.
If you want a pad that can cope with a track day but not be too much for the street QFM A1RMs are great and cheap. If you're street only, then something milder than and A1RM should have better grip cold, and be kinder to the rotors. I've used EBC greens and they were great, but these days i'd probably try QFM HPX or the Remsas (See trader GSL Rallysport for both - also he can recommend a pad based on your usage).
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
