hey guys
im a car enthusiest,love learning about the mechanics of cars,reading peoples build threads etc.
i dont know if anybody else out there has this same problem but sometimes i get lost as to what some acronyms stand for,so i thot it would be cool if people could post the acronym and corresponding meaning.from the most common ones (afm,psi,ebc) etc..to very rarely used acronyms.
would be a good tool for beginners/unexperienced enthusiests to use as a reference.
i would start it off but i better save myself the embarrasmrnt of giving wrong meaning.lol
cheers guys
https://www.sau.com.au/forums/topic/413502-acronyms-and-meanings/
  • Replies 41
exactlo wha im talking about.hav no clue wat u sed.lol
i must b the only guy who doesnt know these things.can anybody bak me up here?lol
Rolling On Floor Laughing My Arse Of at No f**king Idea what EBC (electronic boost control) stands for
That's a start welcome to the forums
Also for psi I'd recommend a science text book....
Edited by Chris_Beli
As mentioned already, EBC is Electronic Boost Controller.
AFM is Air Flow Meter
PSI is Pounds per Square Inch (a pressure reading, you may also hear people refer to 'BAR'. Don't quote me as I have been out of school for over a decade, but I believe this is Barometric pressure, also known as Atmospheric pressure. 1 BAR is equivalent to 14PSI. Feel free to correct me here as I can't be bothered googling it :P).
Other acronyms common to the Stagea realm are:
ATTESA - Advanced Total Traction Engineering System for All-Terrain (thanks wiki), aka (also known as) your Stag's Active AWD system (C34, not sure for M35).
HICAS - High Capacity Actively Controlled Steering (thanks wiki), aka your Stag's 4 wheel steering system.
SAFC - Super Air Flow Controller, a computer made by Apexi for mild tuning of airflow maps.
SITC - Super Ignition Timing Controller, a computer made by Apexi for mild tuning of ignition timing maps.
ABS - Anti-Lock Braking System. An obvious one, but it's better to assume no prior knowledge for the sake of being thorough :P
VCT - Variable Cam Timing
NVCS - Nissan Variable Cam System
There's a few to start :)
Edited by stageaharts
thanks for that bud..ur right its probli best to assume people reading have no knowledge as to the meanings..im sure theres someone
reading this who honestli wouldnt know wat abs stood for.its best people know the correct meanings from the get go.now im sure theres tons more acronyms out there so keep em coming guys
Sadly, it took me 10yrs to learn all those. Every time i find a new one, i just google it for an answer. :D
THTOTF - Tai1or has taken over the forum.
FMIC- front mount intercooler as opposed to the stock SMIC - Side mount intercooler.
BCM - body control module
CAS - crank angle sensor
TB - tuberculosis or throttle body
WOT- wide open throttle . (Vtard favourite)
A/T - Automatic transmission, or if your a yank you seem to put a number in front for the gears 5AT
I know Alex posted this already but I love it! Just for v-tards.
WOT - wide open throttle!
go into the v-tard thread and use it and the'll think your a god! ;p
Oh and v-tard - usually owns a v35 and has NFI on anything.......wait 90% of them don't know anything! That 10% are pretty damn good but must be pretty damned stirred that there big fat brother with a smaller motor can smoke them in comfort! :P
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
