There is a TINY amount of camber adjustment available in the standard upper inner bushes. Not enough to allow 2 degrees. If you have that much neg camber then either one side has sagged to a low ride height (lower = more neg camber) or something is bent.
You need to get it to a suspension specialist to see what is wrong. If you really need to dial out a couple of degrees, then you need adjustable upper arms and radius rods.
Radius rods adjust caster, just the rear upper control arms would be require ;)
Not sure about that - at the rear the radius rod is an upper arm at about 45 degrees to the upper control arm so if your adding length to the upper arm, you will also have to add some length (but less) to the radius rod. I'm just thinking aloud tho.
Usually adjustment of a little more then a degree with the upper control arms will require no other modifications. The R33s and R34s have plenty of toe adjustment from factory so most of the time adjustable toe rods aren't required, the factory non-adjustable traction arms should be fine too.
I've played around with one or two before :P
Edited by Hank Scorpio
On the rear we usally call it a traction rod, in lieur of radius rod which is reseerved for the front only. It's called a traction rod because it controls the rear upright in traction ie; tension in a longitudinal direction due to accelleration and braking.
Cheers
Gary.
Pfffft. Traction arm is a made up name. Just because people use it doesn't mean it makes as much sense as they think it does.
Is a radius rod called a traction arm when it's on the front of a FWD chassis? Didn't think so.
S'got nothing to do with traction. Has got to do with torque reaction and longitudinal location in equal amounts.
If the adjuster is not already at the limit of the adjustment, yes. What do you have currently? If only a single side is a long way out there could be some damage. FWIW the more you lower the car the more neg camber you get, so since the standard adjusters have very little travel you need to be adding something adjustable if its much different from stock height.
Yeah - take it too a good shop even if there's nothing left on the adjuster you will find out what you need to do next.
So if I took it to wilkonson suspension would they be able maybe adjust it a little bit?
:O
I feel so hurt!
But yeah, one of the boys over at Wilkos should be able to help you out :thumbsup:
  • 2 months later...
  • 2 years later...
this thread comes up first all the time on the google search of "how to adjust camber on a skyline R33"
out of all the talking no one actually instructed on the "How to" part.
on the factory camber adjustment bolt, there is a oblong washer connected to a bolt with a hole and some lines on it. which aligns to a notch on the subframe.
can someone please explain how to adjust it? ie, if you move it up 2 lines in what direction achieves what +/- camber angle?
would be appreciated, thanks.
Edited by SilverECR33
I took my car to a shop. I am -2.5 degrees on the driver side rear wheel and -1.11 on the passenger side. There are no adjustments they could do to get the thing straight and they also ran out of time trying to find the cause. This is probably due to me adjusting my suspension height my self with a finger spacing though.
Already done. You're welcome.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
