Hello Ladies and Gents,
Can anyone here tell me whether BBS LM's will clear Alcon V8 Supercar brakes?
I know that 18" will clear the diameter, im more worried about the clearance between the caliper and the spokes.
Wheel size that i was looking at was 18x10 +20.
Id like to try and find this out before i buy a set and find they dont fit.
Cheers, Damo.
https://www.sau.com.au/forums/topic/414033-bbs-lm-big-brake-clearance/
They will clear 365mm rotors, if you are using 376mm Supercar rotors then it will be getting tight but I think will fit.
To give you an idea the Alcon Mono6 kits on 365mm rotors clear those rims, though the extra 5mm radius and the extra width of the caliper means you may be suspect. I know people that run the Alcon Supercar caliper and rotor setup are able to get them under 18" Enkei RP-F1 and also LM GT4s and TE37s.
Thanks Roy. I know that they fit under the TE37s and so on, but they have been so done to death, and every man and his dog has a set, i even have a set of TEs but they are 17x9.5, so they wont fit once i put these brakes on, plus i kind want something different. I dont see many BBS rims on cars up my way.
Even thought of the BBS E88 off the porsche cup cars with the deep centre for brake clearance. Very Similar to the LMs, but more expensive.
I wont risk buying the LMs if they might not fit.
Ill just have to wait and see what i can find i suppose.
You wouldn't happen to know anyone selling a set of Alcon supercar calipers would you? That is the only part of my brake setup i am missing now.
Speak to Risking. He has a lot of touring cars passing through his workshop and deals with some privateer teams.
I just bought some R35 rotors to use with my Alcons...if not I woudl have sold you mine :)
Already on the case thanks Roy, spoke to him a few days ago and chased up a few leads. Nothing so far.
I have AP CP5555 calipers (Troy did I get that right?) on 355mm rotors and run BBS LMS 18 x 9 +20 and they fit fine. Hope that help some.
Hey Nick,
Thanks for that mate. The only concern i have is that im pretty sure the Alcon caliper has a bigger body than the CP5555s, that coupled with an extra 20mm in diameter and im worried that the calipers will fowl on the rim towards the outer limits of the caliper.
I guess the only way to see is to fit the caliper on and test fit with a rim.
Just out of curiosity, how much clearance do you have between you caliper and spokes?
Hey Nick,
Will check for you later (car not with me now) but it's not mega like the curvey spoke design rims like TE37s. From memory nor is it so tight you'd be concenred about it on my set up.
No probs man.
Can you do me favour and let me know the distance from the surface of your disk brake to the back of you spokes, and the distance from the outer face of your caliper to the back of your spokes. That should give me some idea and i can work out the extra distance from the differences in rim widths myself. :cheers:
Thanks Nick your a champ.
Ill have to see if i can dig up some body sizes on these calipers and sus out just how much clearance i am going to have.
Cheers for that guys.
Regards, Damo.
Damo, I am guessing that you will be getting hats and caliper mounting brackets made up.
Remember that you can then shift the caliper inboard a little more (as long as there is inner clearance of suspension arms etc.) if you're doing this...
that may give you ample clearance?
Yeah ive already thought of that. I have all the measurements from my hats and know how much difference there will be between the stock items and the set that is going to go on the car so i should be able to work out how much clearance i will have.
Basically the hat and disc i will be putting on, will be the same overall height if you were to lay the discs face down. So the only real worry i have is the caliper clearance. But i can get the caliper body dimensions, and thanks to Nick, i should now be able to work out whether they will fit or not.
Fingers crossed.
  • 1 month later...
Well i finally got around to doing this (not much spare time lately), and to my disappointment the LMs will not fit at all. I had a look at a 32GTR that was at the meet in silverwater a few days ago that had LMs and a brembo set up from what looked like a 34GTR. It had next to no clearance between the caliper and the spokes. So the massive alcons will not fit at all. Bummer.
Thanks for all the help guys.
yeah i can see that, but the V8 supercar calipers are so much bigger than the mono6 and i have 375mm rotors. it definately wont fit. But thanks for the concern man.
  • 3 years later...
gents!
My appologies for brining this one up from the dead!
Few years back i owned a set of 18X10+20 LM GP's (GTR model) which i sold.. now I want to go back to them again, however this time around i'm running larger brakes than stock S13.
To be exact these are Wilwood 4 piston superlites, relatively small brakes in comparison to many BBK out there. If i had to compare them to something R34 brembo's would be very close to them but i dont have those to adequately determine this.
I would like know for those who have +20 LM what is the distance from wheel hub to the spokes? I need 1.12" of clearance from what i've been able to find on Wilwood's website, or preciselly 28.4mm
I would like to build custom LM's 3PC with new barrels and get biggest lip possible for my non-track wheels :-)
Thank you for the feedback in advance!
  • 3 years later...
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
