Hi Guys,
Selling off parts as the car is gone.
AP Racing 5000+
These are brakes i had purchased off someone else, however i haven't used/installed them at all.
Not sure of discs/pads brands.
I've heard AP calipers are made in England and elsewhere, theses are from England.
Calipers are what they are and include mounts, discs with the hats, all nuts n bolts and pads.
Price is $3,200
Rays CE28 18x10.5 +18, 5x114.3
These are factory matte black in great condition with all stickers. No gutter rashes, just minor scratches from either tyre shops or wheels banging together.
Come with Nitto NT05 275/35/18 tyres made 52nd week of 2011. 3 tyres are 90% new and 1 tyre is brand new due to the previous tyre being poked with a knife.
Do not come with centre caps nor valve caps as they seem to go missing at the tyre shops.
Price is $3,800 with tyres.
R32 GTR Cusco Zero2
Bought these from Jesse Streeter about 2 months ago.
Bought with around 8000kms of jdm road on them.
Price is $1,300
Contact: 0416751515 or PM
Prefer to have this picked up.
Cheers
David
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
