Be good if they could get a good car at Williams. Williams would have kept Hulk but they couldnt afford to not run a pay driver.
As for Massa - he is a nice bloke who used to be able to drive. I dont quite understand it - surely a spring to the head doesnt cause that much damage?
Brain damage is odd like that...
Many many people say Barichello was never the same after his Imola crash, history would support this.
Rubens was very fast in his younger days.
To be honest, I don't get the Massa hate, the guy went within a few seconds of a WDC and has had some stellar drives.
Inconsistent yes but remember, in the year they were together, he towelled Kimi who seems to be every seconds persons favourite homeboy these days.
so..
merc is banned from the young drivers test because they took part in a illegal tyre test and gained an advantage from it.
but the tyres they tested (and gained an advantage from) are no longer being used, so no advantage gained?
so..
The Kevlar belted tyres they tested had never been used until last round at Germany. See how much advantage they got from the test!
Mercedes did not get banned from the young driver test for gaining an advantage, just for undertaking an illegal test, which the FIA told both Pirelli and Mercedes they could do...
There are worse tragedies than Petrov getting a seat at Sauber! Be good to see him get back into F1 as any guy that can defend against Alonso for lap after lap over several GPs is a good driver....and anyone that can outpace/keep pace with Heikki isnt a hack...not to mention that back end of the season he wasnt too bad against Kubica
Lets hope it kicks off and that hack Mexican runs off to Indycar or Nascar
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
