am I right in assuming that if that happens, it'll be the first time the Scuderia have released then taken a driver back at a later date?
Gerhard Berger was the last to do that? Have to think about others, probably be stupidly obvious.
And so it is. Mario Andretti did a famous cameo in 82 after Villeneuve and Pironi destroyed themselves/each other. Also Clay Regazzoni.
Edited by djr81
Felipe Massa has revealed that he will not be at Ferrari next season, with his departure leaving the way open for Kimi Raikkonen to rejoin the team.
Ferrari has spent the last few days finalising its 2014 driver line-up, and it was widely expected that Massa would not be retained.
Ahead of a scheduled appearance at Maranello on Wednesday, Massa duly confirmed that he was looking for fresh opportunities in Formula 1.
In a message that was posted on his Twitter feed, Massa said: "From 2014 I will no longer be driving for Ferrari.
Analysis: Lotus ready with 2014 plan B
"I would like to thank the team for all the victories and incredible moments experienced together.
"Thank you also to my wife and all of my family, to my fans and all my sponsors. From each one of you I have always received a great support!
"Right now I want to push as hard as possible with Ferrari for the remaining seven races.
"For next year, I want to find a team that can give me a competitive car to win many more races and challenge for the championship, which remains my greatest objective."
http://www.autosport.com/news/report.php/id/109804
Did massa just grow a backbone or are Ferrari giving him a chance to leave with dignity?
Well bye-bye Massa! Nice guy, gave it a nudge and deserved to rob Hamilton of his WDC but his time has come
Shame be could not carry his form from late last year into this season...but alas, goneski. PLEASE DO NOT LET HIM END UP AT LOTUS!!111
Why?
Massa and Grosjean would be great crash buddy's..
Many lols would be had. :P
I cant see Kimi going back to Fezz when it was them that killed his interest in F1...but he wants a competitive car. Fezz want results and keeping Kimi motivated and Alonso happy doesnt seem to fit with the team . I suspect Kimi is using this all to push Lotus and perhaps even McLaren. Surely its Hulk going to Fezz
BBC say its a done deal http://www.bbc.co.uk/sport/0/formula1/24042352
"The Finn, who won the world title with Ferrari in 2007 but was replaced by Alonso at the end of 2009, has signed a one-year deal with an option for 2015."
Lotus have said they want Hulk if they lose Kimi.
Massa back to Sauber??? Can't see anywhere else for him.
So Ferrari look a bit silly now. Hopefully a front running car for Kimi but :)
Shame Lotus lost James Allison and couldnt confirm substantial financial stability in the team or that car with Kimi at the wheel could have been amazing next year
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
