congratulations for being around at a time when they hand points out like lollies.
now now, guys in the 70's and 80's were saying the same thing about the guys from the 90's
twice as many races with all their points results counting? talk about unfair advantage
this is just an extension of that
Im sure in 10 years time when 100 points are given for a race win, we'll be looking back and all this will be just a sweet memory
Edited by ctjet
So, what's some donuts worth these days?
€25,000 apparently.
That's going to buy someone and their family a lifetime of curries, with samosas.
They fined Williams $60k because a cross threaded wheel nut fell off the car. They are out of their minds.
Maybe the FIA need to spend more time coming up with a formula that works instead of the crap they endlessly serve up.
the possibility of a loose wheelnut bouncing along a live racetrack is dangerous - think Massa and the spring...
then there's the wheel which could have come off - there's been an example of a loose wheel hitting someone earlier this year...
Edited by hrd-hr30
The possibilities are endless. The reality was absolutely banal and benign. The nut just fell off and went nowhere. The wheel stayed on. The car was going very slowly at the time. Anyone who thinks that is worth $60k is out of their tiny mind.
Its BS...on both counts. The race was over..last Indian GP...newly crowned World Champion...he did it after pit entry. A slap on the wrist and suspended sentence shoudl have been handed to RBR-Vettel.
Then you have Williams...they sure as hell dont design it to fail...didnt want it to fail...yet it happened. It snot like fining them is going to make them work any harder to fix the issue. Its BS. Yes it had the possibility of being dangerous. But look at the STR a few years back whose front suspension just collapsed under brakes. Look at Rubens and Brawn & Massa incident...did he het fined? Its BS!
So only penalise teams for safety breaches if someone get's hurt?
that's kinda my point. An F1 driver knows all this, but he goes and gets a special helmet and makes a big deal out of getting more points than everyone before him. Imagine the furore if Vettel did something like that!
No dont penalise them at all. Clearly something went wrong. They know something went wrong. They will be looking into it and, presumably, fixing it. They dont need the FIA to tell them to fix it. They dont need a fine to tell them they fkd up. They lost a tyre set I would assume and busted some componentry plus they lost track time.
So what difference is a fk off big fine from the FIA going to make? None. So why do it? There is hardly an outbreak of cross threaded wheel nuts in the offing.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
