hey guys i have for sale a full kit big 600x300x100 intercooler with 3" piping all the way with a trust type R BOV (Stiff spring type) welded on hidden under the drivers guard, all to suit rb26 in a R32 GTR or gtst if converted. Chasing $700ono for the entire kit only used for 2000kms, prefer pickup however will post but will cost a bit, will separate kit if no one wants the lot. Includes clamps and all silicone joiners.
Located on the gold coast PM, call or txt Johnny 0414596256
Edited by slidinr32gtr
  • 1 month later...
