3 piece = Genuine Nismo Side Skirt.
1 piece = Fake.
I'd never sell the 3 piece and keep it on the car.
But if you do sell it, make sure you get a good price for it.
Off topic: I'd prefer you to spend the money on a Nismo Front Bar.
As above, Don't sell the original 3 piece side-skirts. (unless you sell them to me :yes: )
Trust style rear pods turned up today from JSAI :thumbsup:
might order the single piece N1 sides to replace my 3 piece N1 sides now
Nice. Josh does turn stuff around quickly. When I finally crack my front bar I'll get a new one from him again, his stuff looks great.
Looks like I'll have an christmas holidays project on my hands lol.
I'm thinking something similar to the R34 GTR diffuser, I want it to have an OEM feel.
Its going to have to utilise some form of rear pod to tie it all in though.
  • 4 weeks later...
Hmmm that's not bad, I might make an alloy one and see what I can come up with.
How did you go Anthony, did you try and fabricate a rear diffuser?? If so, pics!! :yes:
The Abflug ones are nice
I hate how that goes beyond the sides of the rear bumper. Is there a company that makes a diffuser that doesn't spread wide like that?
Edited by Bigalow
Didn't get time :(
Working on my house, my old lady's house and the grand parents house took up all of my "holidays".
I have found a rear bumper lip that looks similar to the bottom of the R34 GTR bumper and it has what look like trust pods moulded to it.
Ill try get a good quality pic of it asap.
  • 1 month later...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
