To smart R30 people, can the rear brakes off this car be bolted onto a C211 japanese import coupe?
Cause if so i would like to inquire about the pricing of all the rear brakes and also the rear stub axles which i assume are the same 4x1 bolt pattern as the C210
I'll look at all my notes when I get back home. I'm currently in Qld till 6 or 7th and let you know.
Cheers,
Dennis
Works 510, it is a full bride interior, black and grey, but the front seats are sold.
What i am selling ar ethe JIC adjustable coilovers. I am open to offers but would need a set of standard rears to replace them with so it still rolls (i have a set of standard fronts already)
Excellent condition, adjustable tops etc. i will remove them and have a look at the spring rates etc.
yeah i should be able to chase up some stock rear struts.
what sort of price are you looking to get for them?
Any updates for this guys?
Masters, the door trims etc will now be staying with the shell. The shell is on ebay at the moment for those interested, still has most gear including coilovers, bride interior minus front seats, etc etc...will sell entire car for cost of paintjob. the nicest shell i have seen.
  • 4 weeks later...
  • 4 months later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
