hey guys,
Up for sale is my Fujitsubo giken exhaust
76mm or 2.75" exhaust, with a 4.5'' tip- very nice sound
doesnt sound like a tractor on idle
low rpm has a nice tone
high rpm above 4k gets real angry and aggressive and sounds really tough. jasma certified
exhaust is in good condition wth no cracks or leaks or dents or holes.
lots of pics as i know eveyone loves pics,
exhaust is located on the central coast,
can ship interstate at buyers expense.
asking $600 or make me an offer........
call or txt anytime, 0409076032
kane.
https://www.sau.com.au/forums/topic/414750-r34-gtr-exhaust/
anyone????
$400
its an absolute bargin!
if your looking for a tough sounding aftermarket exhaust this is it!
i have a video clip i can show you and it has excelent sound so you can hear what it sounds like
https://www.sau.com.au/forums/topic/414750-r34-gtr-exhaust/#findComment-6674688
I can vouch for this exhaust. I have the same on my car and below 3500rpm it's quiet but not as quiet as the OEM cat back. Once passed 3500-4000 rpm it does a really nice noise.
Fitment is perfect also.
GLWTS
Edited by wardiz
https://www.sau.com.au/forums/topic/414750-r34-gtr-exhaust/#findComment-6674803
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
