  • Replies 120
Posted Images
Washer bottles $60 each..
BBS 17inch 8+35 and 9+35 $1100- (genuine)
under dash trim panel $15-
white surround $50
Rear parcel shelf $60-
A Pillar trims $30 each
speedo cable $90-
glove box no key $30-
center console dash panel radio surround $50-
mint black center surround $100-
Rear quarter trims $30 each
rear seat belts $80- front seat belts $70-
nissan din pocket (shelf for under cd player) $20-
rear trim $50
headlights $250- reo $100 bonnet $80-
driver side dash vent $50
climate control panel $80-
hand brake cable and hand brake $90-
4.3 R200 stock LSD $150
Edited by 05lde
R32 mirrors $70 each
2xaircon climate control $80 each
headlights $250 a pair
bonnet $80each
front calipers and rotors $200
Front LCAs $120 a pair
front r32 reo $100
r32 brake master with booster $120
r32 clutch master cylinder $30
brake and clutch pedal $150
manuel rb20 tail shaft $100
dash $400- comes with all vents non cracked.
door cards $50 each
washer bottle $60
rear window $500
drive side window switch $100
window reg switch sensor box $50
window reg $100 each
door shell $100 each
boot no wing $100
stock diff $150
steering colum surround $50
fuel tank $150
tail lights $60 each
rear reo $100
rear bar $80
dash cluster $80
cluster surrond $80
carpet $100
rear parcel shelf $60
GTR front strut bar $100
CD/gear shifter surround mint condition $100
CD/gear shifter surround painted white with top crack but not all the way through $50
gear boot $15
hand brake boot $10
nissan din pocket $20 (the little shelf under cd player)
side skirts $140
rear pods $100
Tein HE drift coilovers $900
sun visors $10 each
rear veiw mirror $20
glove box $30
rear ashtray from centre console $20
under steering wheel panel $30
BBS 17inch 8+35 and 9+35 $1200-
rb20 speedo cable $90-
washer bottles $60 each
rear parcel shelf $60-
A pillar trims $30 each
glove box $30-
rear quarter trims $30 each
rear trim $50-
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
