Quick update. Bought a few bits and pieces to get this thing closer to driving somewhere.
I managed to get a good haul of parts from a local guy in Melbourne who had to clear out his warehouse. Got 4 doors with windows, boot & bonnet, cluster, glove box, steering column, din pocket - all for a couple of hundred bucks. Very pleased
Little jobs done:
  • Fitted new dash cluster
  • Rewired horn so it actually uses the horn button (was using a little button near the ignition previously but it was a pain to push in a hurry)
Also got some clear indicators thanks to works_510's hot tip. They are a 99% correct fit for the standard Cefiro front bar indicators. Upon fitting I found out some genius has cut the plugs off!! >.<
Only about $45 delivered so I'm super happy with them: http://www.ebay.com.au/itm/170816545537?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Other bits....
Rubber grommets to the little hole where the wiper was. Also got a grommet for the space wheel well.
D21 Navara speedo drive to convert my RB25 electronic speedo to the Cefiro's mechanical one. The speedo hasn't worked in the car since I got it so I'm looking forward to actually having a speedo instead of guessing based on the revs! Just hoping that the sending that is in there at the moment is still and RB25 one....
For anyone that needs to connect and RB25 speedo in a Cefiro there is a great guide here: http://www.jdmlegion.com/KnowledgeBase/Engine%20and%20gearbox%20conversions/Making-a-mechanical-speedo-sender-for-the-RB25-gearbox-f0271b89-cd6e-425d-bc0a-ee62f51dfaa7
Edited by konect
  • 3 weeks later...
  • Replies 47
Posted Images
  • 5 weeks later...
Well well well chaps, bit of an update here...
Dan - Probly a couple of months away from rego and a track day. Nearly ready for rego but I'm going away for 3 weeks which puts it back. Want to get it retuned before I hit the track.
I bought some cheap xxr rims all round with a higher offset and smaller width so they look a bit more reasonable for the street. 9.75in +20 all round but don't have a decent pic as yet so heres a shit one...
Also after doing a heap of searching for silencers that would fit my exhaust I gave up and made my own. In hindsight it actually wasn't that hard and they came out alright. They cut about 5db off the exhaust and remove the deep rumble which the neighbours are enjoying being gone.
post-18824-0-29196500-1366018188_thumb.jpg post-18824-0-89234500-1366018194_thumb.jpg
Finally put my navara speedo sensor to good use and did the conversion mod only to find out that it is the cable that has snapped...the sensor was fine! Ah well, its done now. I read a couple of guides and didn't like their brackets so I made my own. It's 2 pieces of 1.6mm sheet shaped and welded (in hindsight - use 3mm straight off the bat next time). I cut a groove on the side closest to the bolt too so the bracket creates a fork over the sender and then bolts in. This means the sender can't rotate because it is held in place by the 2 sides of the fork.
I have to order a new speedo cable but Nissan wanted $154 for one so I'm waiting on a price back from Jesse and see if Nissan Japan can do any better. If any one has a hook up at Nissan give me a yell. Best price I have from AU is $115 delivered.
Couple of pics for your enjoyment...
Bracket
Slide it on from the back after fitting the sensor. I left a fair bit of metal on the back as there is space and it makes it easier to fit / remove.
All connected up (with the broken cable) and bolted in. Bracket is super tight with no movement. Not bad for an hrs work in the shed.
Hopefully next update will see it off the jack stands and rolling again.
To do in the coming weeks:
  • Raise front coils
  • Wire front indicator wires and fit indicators
  • Replace cat gaskets as both sides are blown (want to fit an Apexi ECV first - having a drainer of a time finding one though!)
  • Fit new speedo cable once it arrives
  • Refit interior dash pieces
I think after all that it will be almost rego time!
Edited by konect
thats a fair call dont want it to lean out on the track.
for the speedo cable i'm using a vl rb30 cable for 20 bux at the wreckers, broke my other 2 r32 cables on skids so the vl one is a bit more sturdy and is lasting me longer
Interesting.....
I heard that the VL turbo ones work but I'm not sure about one from the wreckers...might just break again. But for $20 I might give it a go. I could buy 5 of them for 1 new cable haha
All good. Jesse said a brand new one is $100 delivered so I've ordered one.
Spent some time today removing the cat and as usual had to grind off at least one of the exhaust bolts. Someone had already had a go at removing it in the past and rounded it nicely. Also while I was under the car I noticed a crack in the floor where the trans tunnel meets it and obviously the exhaust has been bashing against it and creasing it in the past. Pulled out the welder and closed it up before it spread any further :)
Also ordered one of these bad boys today - I liked that the lever was a bit more user friendly than the Apexi one and it was ~$30 cheaper delivered.
http://www.frsport.com/Circuit-Sports--EXV-M076-WK-3--Exhaust-Control-Valve_p_37639.html
Edited by konect
  • 1 month later...
Finally had some time to work on the car and fit all the little pieces after getting back from overseas. Took the car of jack stands for the first time in about 2 months and took it for a spin with the new wheels on other goodies.
ECV
ECV arrived from the US just before I left. Put it in when I got back and managed to route the cable perfectly over and around the gearbox, up through the firewall next to the speedo cable then behind the centre console and mounted the little lever on the passenger side (no pics yet though...)
post-18824-0-03697400-1369570412_thumb.jpg post-18824-0-60053100-1369570415_thumb.jpg
Speedo cable
This package arrived while I was away and was a nice little present to have waiting for me. Was pretty easy to remove the old on and put this one in. I haven't tested it with the cluster in yet, but I can see it spinning when I took the car for a drive so I assume it will work!
Ended up being just under $100 delivered from Jesse which I was happy with.
Current state
Finally got to take a pic of the car with the new (temporary) wheels on it. I actually don't mind them, but they need to be spaced out after it gets rego. Front left corner still needs to be raised more. The coil has shit itself from the drive home from QLD when I bought the car so I'll have to get another set in the near future.
post-18824-0-91625800-1369570635_thumb.jpg post-18824-0-64819300-1369570638_thumb.jpg
Also done a heap of little things like wiring front bar indicators, plugging little holes in the floor, cable tying some wiring etc etc.
Things to do before I get it inspected (ETA 2 weeks!)
  • Move boost gauge the A pillar (have a gauge cup waiting at the post office to pickup Monday)
  • Put the cluster and surround back in
  • Tidy the inside
  • Raise the front left a but more
  • Fit indicators to front bar (either the indicators are a bit big, or the slot in the bar is a bit small....)
Nice work man, I got the Apexi version of the EVC and I love it.
Great for those times when cops are around or you come home late and don't want to wake the neighbors.
Keep up the nice work!
  • 1 month later...
Some updates. No pics unfortunately.
Upcoming activities:
  • Relocate battery from the back seat to the boot and move the kill switch to free up space for gauges in centre console
  • Fit gauges
  • Put the old exhaust back on, get a dump/front and get a shop to put it all together
  • Do LS2 coil conversion to remove misfire
  • Get it tuned
  • Etc etc etc etc (the list goes on lol)
  • 1 month later...
Finally got around to taking some pics to update this thread! I've been relatively busy with the car and have actually been able to drive it around - feels amazing :closedeyes:
I ended up buying a new 100 cell cat and getting a local exhaust shop to weld it up and align the exhaust properly. $80 well spent, saved me the headache of trying to weld under the car. Been driving it around with the mufflers in and it has a reasonably acceptable noise level haha. Had to trim the rear bar for them to fit but is looking good. Can't wait to hit the track with the mufflers out!!
Finished my new gauge installation with its array of switches. I still have to make labels for them but I know what they are so im not too stressed about that.
Made up the bracket from a single piece of aluminium which screws into the stock stereo holes. The gauges have a shit load of wiring to them so I had to draw out a complete wiring diagram to make sure everything works. Here's a run down on what each bit does:
  1. Oil temp
  2. Oil pressure (shown in Bar - car was off at time of photo)
  3. Water temp
  4. Warning buzzer - Each gauge has configurable warning levels switched by an internal relay. All 3 gauges are negatively switched to the buzzer so when the internal relay switches upon hitting the limit it will start the buzzer flashing and beeping (FYI - its really loud)
  5. Switch for buzzer - I added a switch to the buzzer so if something goes wrong and I'm aware of it, it doesn't continually keep beeping at me!
  6. Switch to allow radio, clock, central locking to work when the kill switch is off. When it is on it allows current to pass through a 15amp fuse across the kill switch terminals so if you try and start the car without the kill switch the fuse blows. When it is off it means the car is drawing no power. I have to get used to this as I've blown the fuse twice so far lol
  7. Kill switch
After getting sick of hearing every little noise I spent this week making up 2 sheet metal panels to cover the holes where the rear seat and parcel shelf used to be. I've covered all holes and re-routed all the wiring to run through a single hole which I still have to cover with some rubber. It makes a MASSIVE difference to the noise level inside the car and also will allow me to run an external fuel system if the times comes. For all the small holes I tack welded metal covers over them then sikaflexed around them to ensure a complete seal.
I still have to put the other piece of carpet can in but you get the idea....
Battery has been relocated to the boot. After much deliberation I finally decided to go for the lowest centre of gravity and weld up a platform for it to sit on in the spare wheel well. The clamp is attached to the steel bracket so its not going anywhere. I still need to buy a circuit breaker which also be mounted in the boot to avoid any melt downs if there is a short. Also welded a bolt to the floor to create a good grounded point for the battery.
Things still to be done:
  • LS2 coilpack conversion. I've ordered the coils & pigtails from the US and once I decide where to mount them I'll order the leads too. I've heard great things about these coils making RBs run super smooth and can do the conversion for ~$300 so I thought I might as well do it before getting it tuned.
  • Get it tuned
  • Do a track day!
Looking good. Have you driven it much with the exhaust valve closed? thinking of doing the same.
Keep waking my 18 month old up when I leave for work!
Yeh I was doing bit of noise testing with it yesterday. The valve can close FULLY (which is just stupid) so where I have it mounted I pull it down about 2/3 of the way.
The best way to explain it is that it takes the 'gurgle' or 'rummble' out of the exhaust. So it is still loud but doesn't have that aggressive tone - hopefully that makes sense. I'll try and take some video of it.
  • 4 weeks later...
Sooo progress has been made.
Car now has some GM in it with the LS2 coil pack conversion completed. I'd HIGHLY recommend this conversion to anyone. I started the car (very nervously) and waited for the revs to start hunting but they didnt. Stock dwell settings and the car runs much crisper than it did with the splitfires. Doesn't bog down if you don't give it enough revs now either - can't wait to see them at full power with a tune!
Tune is booked for 30/9 so will be good to see how it runs after that. Then just need some tires and its track time! :)
  • 1 month later...
Not much to update here...tune got cancelled as I've had a vibration develop somewhere in the driveline. Comes on about 70km/h and shakes the whole car.
Done a few things to find it so far with no luck. I've ordered a Nismo gearbox mount with some new cross member bolts and if this doesn't fix it I have no idea.....
Hopefully have more news soon!
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
