Hey guys and girls.
I'm new here and own a 97' R33 Gts-t.
The Missus wants us to have a more family car, so what better then a Stagea!.
I know its hard to judge and tell just but the carsales add, but if i could get some opinions on this one i would much appreciate it :)
im pretty new to the Stagea world, so all the help i can get would be awesome.
Thanks, Kurt
http://www.carsales.com.au/dealer/details/nissan-stagea-1999-12631387?base=1216&vertical=Car&cr=12&page=2&eapi=2&__N=1246+1252+1247+1282+4294963846+4294960181+903+1216&num=15&silo=Stock&sort=default
https://www.sau.com.au/forums/topic/415413-thinking-of-buying-a-stagea/
had the 100k service = fake kms
i would say its been in an accident too, if you get it checked out professionally with warranty could be ok, still a little expensive
edit - the passenger head light looks fogged up also
Edited by BigBoyDan
Hey guys and girls.
Thanks, Kurt
http://www.carsales....ck&sort=default
could you be more specific about what u want to know??
totally agree its definately had the front end resprayed and the clock is wound back. its over priced to hell for an auto.
damn, getting turned of it now you think there fake kms and had a hit :(
fairly obvious actually. the clock says 75,000 but it still has the japanese 100,000km service sticker on the airbox. obviously to stupid to peel it off. the paint forward of the front doors looks fresher than the rest and the rad is skewed on the mounts. which is a great indicator of a front hit.
my hearts not set on yellow at all, lol...would probably prefer non yellow.
that one uis alot better but its in another state :(
give the "purchasing a stagea" thread a really good read mate. then make sure every car u look at is thoroughly checked over. and the best advice you will recieve about the stagea section is to use the search function ALOT all your questions will have been answered time and time again.
Hmm, this one is actually closer to where i live...had someone tell me once though not to go past 99' models anything later are not as good??
dont say stuff like that, or this will turn into another C34 VS M35 thread. lets just say they're all good
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
