ph1- great figures there, got cam gears but maybe the guys adjusted them more for top end power??? I dunno....
I think the power these turbos are pushing is expected, how much more power do you think they should be pushing out???? 325rwkws @20 psi compared to your 317rwkws @ 18psi, seems about right doesn't it, taking into consideration you got bigger cams??
Maybe with bigger cams I shall I expect about 340rwkws @ 20psi or even 360rwkws @ 22psi???
I guess we'll never know until I get the cams and retune, with emphasis on adjusting cam gears for low/mid range (when turbos begin to spool)
Anybody have any comments/feedback???
Also just to emphasise I'm not only interested in power, but also concerned about response and lag..
As for bigger camshafts, they're definetly on the list...
  • Replies 136
Jack,
I think ph1 has spent some big$$ on his motor , forgies, rods, etc etc.. and running big boost shouldn't be a problem for him... like he said, your turbo's would more likely be a better set for his car as his 8cm trust are running out of puff top end. Unlike our set-ups, we're still running stock internals, limiting our option for more reliable power. I also think the boys have tuned your car to be on the very safe side. Like you, I am happy but want that litle more now. After a chat with Emre, he got around 400rwkw with the GT2530's on stock internals, but obviously running that sort of power continually, something has to give. Based on Emre, I think we can still get alot more power out of the cars, but how far before something give's. Ultimately my next option would be motor work, but that's unlikely at this stage.
meshmesh- Your spot on, there's definetly more in it, even Nigel said for me to get used to the power, and then bring it around if I want more in the future.... But it all boils down to how long you want your motor to last!!!!!! I'm sure with c16, heaps of timing and 2 bar of boost, my car should be capable of 400rwkws aswell, but not willing to sacrifice the engine at this stage.....
OK.. I tried to compare my first dyno run "which needs to be said, was done in shootout, and on a different dyno as ICE hadn't got there's yet".. & Jack's dyno which was done on ICE's which was not in shootout. But for the time being I thought it would of interest. The thing I noticed most is the trust makes quite some power from 140-170km/h, and keeps on going, where the HKS just flattens out from 140 onwards.
.................TRUST......HKS GT2530
KMH...........KW...........KW
80.............50.............60
95.............80.............90
110...........113...........140
125...........160...........220
140...........240...........280
155...........307...........298
170...........320...........319
185...........324...........320
195...........324...........321
KPH-------Trust-----HKS--------Diff
80----------50--------60--------20%
95----------80--------90--------13%
110--------113-------140--------24%
125--------160-------220--------38%
140--------240-------280--------17%
155--------307-------298--------(3%)
170--------320-------319--------0%
185--------324-------320--------(1%)
195--------324-------321--------(1%)
Average---213--------228--------7%
Am I reading this table right? The 2530's have 38% more power at 125 kph than the Trust's and their average is 7% (15 rwkw) higher?
Hi SK,
I guess so.. unless I've made a boo boo?? I used Jacks dyno from this thread and my dyno from my thread http://www.skylinesaustralia.com/forums/sh...347&postcount=2
EDIT: If I can also add, My first dyno run was done in Shootout, Jack's was NOT in Shootout. And some say Shootout adds around 10%~. I'll try to get copies of both our runs which were done on the same dyno.
Can I be part of this comparison too? :thumbsup:
Absolutely, if you have low mount turbos...
No point in comparing if you have a T88 strapped to the side, you're goals are completely different to Jack's, Simon's and my own.
I'll have a completely built engine, so I could strap on a T51R SPL and turn up the boost if I wanted to, but that's not what this comparo is about.
meshmesh- yeah did a similar comparison with the two graphs, but since they were done in different modes, thought it would be inaccurate and inconclusive....
ula32 & NRB- yeah sure!!! I would like to see how ula32's N1's compare to both the 2530's and T517Z's.... NRB, what turbos you running???? This will a very interesting comparison!!! All we need is somebody with the Apexi AX's and we've got the set!!!!
Hi Jack, Agreed!
I think NRB has 2530's aswell??
Should be good to have them all on the same dyno same time, just need to hassle the boys at ICE. I spoke to Nige about it, but he said it wasn't necessary as seeing I did my last dyno tune on his dyno when we pulled back some timing, and he had both our runs on file. It was just a matter of pulling them up?? I'd still want to organise something. It'd good to have Merli ther aswell, however I think by the time he finishes his car (Unfair Advantage - Motor Mods :D ), he'll be struggling to pay his fuel cost down to Melbourne so we might have to fork out some $$$.
hehehe... I won't drive it down.. I'll probably get it trailered...
And I'll have internal mods, yes... But if you think about it, they don't add any power really. Especially not at our power levels. I could strap on the GT-SS onto the stock motor and be fine...
Forged pistons, forged conrods and the rest of it doesn't add any power, it just makes the motor more reliable (and allows me to run a big hit of nitrous :D)
If the new forged internals are lighter in weight than the OEM parts, then surely the reduction in mass would result in a slight horsepower advantage? At the very least you'd expect an increase in response.
Edit: Just adding to the above... A friend/ex-work colleague of mine (Simon Butterworth) used to run an 8sec Thunderbird drag car. I recall him mentioning how they aimed for incredibly light weight internals so they could maximise horsepower. Obviously there's a big difference btw an 11sec GT-R and an 8sec drag car, but the same principles apply.
That's true Matt... Carrillo rods are VEEEEEEEEEEERY light ;) ;) :D
So maybe a slight increase in response and a little more power from reduced rotating mass :) Won't make that much of a difference though I wouldn't think... But I hope I'm wrong! :D
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
