Wrecking a Black R32 GTST Skyline Coupe after front end crash
Ask for anything else, not mentioned - everything must go and all for sale from $5... make an offer!
Doors (with door cards), front & rear bumper, side skirts and dash have sold.
  • Immaculate LED rear lights - finished in gloss black (pair)
  • Autotecnika steering wheel and boss kit
  • KYB New SR lowered springs, shocks and struts. Very nice firm ride, good condition front and rear
  • LSD - good condition, automatic
  • Strut braces polished alloy
  • Racepro brand new never used manual boost controller
  • Racepro brand new never used blow off valve
  • 3inch cat back exhaust, exits with twin 2.5 inch tips
  • Boot lid - black, excellent condition, no dents etc (no spoiler)
  • Very average condition matt black bonnet
  • Front headlights - very good condition, no cracks in glass - no bulbs
  • Standard 4 pot calipers, disks and pads - very good condtion
  • Front nolothane control arm bushes
  • Rear quarters (not cut yet - whole shell is good from firewall back)
  • Rear drivers side quarter window
  • Windscreen
  • Front and rear wipers - working
  • Windscreen wiper motor
  • Standard brake booster and master cylinder
  • L & R visors - with mounting brackets (pair)
  • Rear vision mirror (with mounting brackets)
  • Lower sill trims (pair)
  • Interior light - excellent condition, no cracks in plastic cover
  • L & R interior A pillar trims
  • Rear quarter internal trims
  • Rear seats - good condition
  • Front seats - not matching trim cloth, driver's seat in good condition, passenger seat is in average condition - will sell as pair or seperate
  • Seatbelts
See link below for all photos of everything mentioned above
http://postimage.org/gallery/7jwj1n5q/
Located in Brisbane, happy to ship smaller items at expense
PM or contact 0406 168 285
https://www.sau.com.au/forums/topic/415441-r32-parts-for-sale-all-from-5/
  • Replies 45
UPDATED - everything with no price is just cause im not too sure so any reasonable offers will be accepted
  • Boot lid - black, excellent condition, no dents etc (no spoiler) - SOLD
  • Windscreen - SOLD
  • L & R visors - with mounting brackets (pair) - $25
  • Rear vision mirror (with mounting brackets) - $30
  • Lower sill trims (pair) - $40
  • Interior light - excellent condition, no cracks in plastic cover - $20
  • L & R interior A pillar trims - $60
  • Rear quarter internal trims - $60
  • Rear seats - good condition - $150
  • Front seats - not matching trim cloth, driver's seat in good condition, passenger seat is in average condition - will sell as pair or seperate - $50 pair unmatching upholstery
  • Seatbelts
http://postimage.org/gallery/8wea5cu6/
located in Everton Hills, Brisbane
UPDATED - couple more parts found and more pics below
Rear ash tray
Glovebox (missing the button)
Boot hinges - perfect working order
Bonnet release & cable - working
Air con and clock front cover
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
