Sorry - I fail to see how sticking a comic on your wing is "pushing the boundaries"....
I have some respect for these guys because of the hands on approach, but this car sucks teh hairy balls, and only appeals to honda fanbois it seems
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6671896
i think people missed the point of this car. Marty & Moog's season finale builds are always built with a certain amount of piss-taking (literally Moog's case) and satire. Just look at the TRD Laser and their Civic build.
In this case, the satire is less obvious because this is the fashion nowadays. But you can see the guys aren't taking this thing too seriously. Look at Moog constantly saying this is "what the kids are doing" and "the internet told me to" throughout the episode.
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6674783
I'm still hoping for a final season eposide where they build the ultimate bogan commodore...
Would be pretty easy & cheap to do I reckon.
1) Buy cheap VN commodore
2) Chop the springs
3) Buy a set of 20"chromes from bob jay for the back + retain a set of factory steel wheels for the front
4) Buy some clear tail lights off + Unit/Skin etc etc sticker off ebay
5) Drill some holes into the exhuast for that epic V6 noise
6) Add the chev bage at the back (leave holden badge on front) for the final touch...
Any other steps I missed?
Edited by Mayuri Krab
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6674792
2) Chop the springs
The chromies should be on the front of the VN with stockies on the rear for crazy single peggers or if you want to be a pro drifter welded diff for when you want to enter it in the D1GP
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6674882
Thank you, I couldn't be bothered trying to explain it but you have done it for me.
I really enjoyed this episode and MCM is by far my fav channel on youtube
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6675704
I disagree. There were elements of satire in there but their closing comments and interviews lead me to believe that they thought that build was cool. They then add a bit of satire to the program so they can sit on the fence, see peoples reactions and if many people hate it MCM say they were just taking the piss. Episode is fail.
I like the fact they are from the area I grew up in and as a previous poster said the DIY aspect of MCM is great but they destroy cars that a young fella on his Ps would love and modify. Hacking a Subaru Vivio in half was a travesty. I would love one of them right now.
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6676333
Pffft... At least there not getting drunk and wrapping them around poles. Do you have any idea how many second hand cars there are in the market?? They are entertaining hundreds of thousands of people and using a few cars out of the millions on the road.
Quite a few of their cars have been sold onto new owners who absolutely love them.
https://www.sau.com.au/forums/topic/415513-mcm-do-it-again/#findComment-6677358
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
