Piping came off yesterday.
Once I've had breakfast get to those annoying bolts on the turbo flange one or 2 of them have come loose.
Explains why car bogs down not enough air on boost being pushed through
Finally.....
The skylines been stranded there with a jammed wastegate for about 2 months.
Now i can roll it back onto level concrete and get under it.
Now im not using the garden shed as a workshop ill make a Kudos order on monday to get the other bits i need. Then the fun begins.
My poor old back needs a rest though.
>_<
Rims soon... If not today, defs before Sunday.
Have you got your Airbox yet? Gonna fit it up?
I washed mine yesterday morning but the Golfball sized beetle that hit my windscreen at 110km/hour kinda ruined the effect. :laugh:
Conditioning and charging the battery, its been sitting for so long, i hope its going to hold a charge properly.
Moved all the important stuff into the new garage, parts are coming, i can start serious work on the car soon.
Cant wait to get it back on the road.
Oh yeah
Thanks Richard :D
Edited by D.I.Y. Mik
Sick! ShitBox Stealth Mode. :ninja: I must contribute towards this! Not cashed up just now though - soon. :D
Richard if you need to get ARC filters, get in touch with Andrew "kudos.motorsports" - give him the dimensions and he might have some on the shelf. (I got mine through him)
or
If you want K&N filters get on the K&N site and you can find appropriate filters by inputing dimensions! The one for to fit mine is for a BMW X6.
needs racing stripes!
and ive donated! also, can i donate a rear wing? :)
I did this :)
Donations can be made here ;)
http://fundraise.shitboxrally.com.au/skyline
I also did that yesterday. Enjoying it lots
PTSHHHHHHHHHHHHHHHH is that the fuel out the exhaust ? :P
Get a tune and make it go away or I'll just have to stay in front of you.......... :middlefingerup:
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
