Tidying up my man cave today.
Going to clear out my garage and use that concrete paint on the floor.
Have painted too many small parts on the floor of my garage. So has templates of parts all over concrete - lulz.
R32GOJIRA is dropping off rocker covers for me.
Will get them professionally coated and put them on soon :D
and that's what I'm doin'
and yes - Zip ties (have 3 sorts if you wanna come round Eric)
Edited by Sinista32
What a s#*t fight that was.
The pod enclosure doesnt fit right and consequently partially snapped. One of the bolts does not fit on the front. Had to aryldite the place where it partially cracked.
Air guide fit ok, not real flush against the top of the grill though.
The perspex it is made out of is too thin. Quality not to flash really.
I will be writing into where I bought it from.
Looks ok for now. I will buy some metal ones I think!
On the up side I fixed the part of my grill that I found broken!
eXcuse me if I sound happy. I am
S!Ns man_cave grand re-opening Wednesday.
needs another coat tomorrow :yes: currently watching paint dry - Tee hee
Got the rear view mirror last week (thanks to ...well you know who you are. cheers for all the OEM parts this year :yes:).
All painted satin black & installed.Need a few more things :)
Saw your post and expecting some good things coming your way - can't wait !
Ordering a complete new lock set and ignition barrel to install. Boot lock doesn't match key WTF, think in the mix n match I've lost it :(
Thinking I will cut my Nismo key to suit (not much use just to keep looking at it). :touch: has to be 50 killerwasps right there.
Edited by Sinista32
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
