Tidying up my man cave today.
Going to clear out my garage and use that concrete paint on the floor.
Have painted too many small parts on the floor of my garage. So has templates of parts all over concrete - lulz.
R32GOJIRA is dropping off rocker covers for me.
Will get them professionally coated and put them on soon :D
and that's what I'm doin'
and yes - Zip ties (have 3 sorts if you wanna come round Eric)
Edited by Sinista32
What a s#*t fight that was.
The pod enclosure doesnt fit right and consequently partially snapped. One of the bolts does not fit on the front. Had to aryldite the place where it partially cracked.
Air guide fit ok, not real flush against the top of the grill though.
The perspex it is made out of is too thin. Quality not to flash really.
I will be writing into where I bought it from.
Looks ok for now. I will buy some metal ones I think!
On the up side I fixed the part of my grill that I found broken!
eXcuse me if I sound happy. I am
S!Ns man_cave grand re-opening Wednesday.
needs another coat tomorrow :yes: currently watching paint dry - Tee hee
Got the rear view mirror last week (thanks to ...well you know who you are. cheers for all the OEM parts this year :yes:).
All painted satin black & installed.Need a few more things :)
Saw your post and expecting some good things coming your way - can't wait !
Ordering a complete new lock set and ignition barrel to install. Boot lock doesn't match key WTF, think in the mix n match I've lost it :(
Thinking I will cut my Nismo key to suit (not much use just to keep looking at it). :touch: has to be 50 killerwasps right there.
Edited by Sinista32
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
