Hi Jimmy - as you know I have but I went the new outer window trim route.
I'd go have a look at either Spotlight and look for something similar in a material.
It's like a white shag small material.
Remove the existing bushes (both). - Use a hand held razor blade and maybe some turps to remove the glue.
Glue the new bushes to the plastic backing and let dry
Re-Install.
Both sides :) (bout 30mins effort)
Perhaps Supercheap or Bunnings may have something similar.
It's really just a 4-5mm bushy length and around 3cm x 1.5
Cheap as cheaps way to replace.
and remove and rinse every 3 months or so to stop the dust scratches re-occurring on the glass
(fairly certain you cant buy just that piece and clip in :( )
Edit: PS new external window trim farkers aren't cheap)
Edited by Sinista32
Hmm - might have been around $115 each I think when I bought mine. But postage is very exy due to length.
all air postage out of Japan is daylight robbery.....SAL less so and sea cheaper still.
Paid $90 bux freight recently for an RH9 alternator. Half the size of a shoe box !
Best idea is to compile a list and save for it all. Then buy and use Sea as delivery method (6-8weeks)
My issue is I cant wait so it goes DHL. RHD & Nengun are my favourite Jap shops.
Some costs - Rear window Trim (only) is $330. Qtr windows about $220 ea.
OEM Windscreen $1700, Dash $1100ish (NAL). OEM GTR Steering wheel around $1k deliverd. C-pillars $140ea
Very True indeed Kat - It is good checking Nissan spare parts first and they don't seem to fluctuate with exchange rates if the parts are in country.
My issue with calling them previously is there not real helpful and never call back. (but I don't have bewbs :/ ) They can be a lot more expensive too and sometimes cant get what you see on RHD/Nengun.
But now having an insider the service is brilliant :thumbsup:
Must admit I picked up mine even cheaper still off someone who bought new, with horn button, and didn't unpack it. Win
I actually lost my insider so I may hit you up at some point knowing that!! :D
I do buy most on RHD admittedly.
Floormats arrived for the GTR on Thurs, they're better than the looked in the pics. Now got to get them to carlovers or somewhere with a steam cleaner for some love!
Door trim (as in inner door card to be specific)
http://www.amayama.com/search/?q=80900-05U00
http://www.amayama.com/search/?q=80901-05U00
There's the parts for both left and right. Label on box has them as "Finisher-Door"
Yep, all of their stuff is NEW OEM :)
By door trim, I meant rubber strip for outside of window, confusing myself haha
Edited by Scar
:excl: HAIL ALERT! :excl:
Small hailstones in west belco, so its heading your way.
Not damaging yet, but can easy get bigger without any warning.
Yes had small hail here earlier (bruce) Edited by Scar
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
