Nice work Rob!
Bit of a let down with the fact it's not hitting 200kw but not too long and you will be there.
I have decided I'm not going to chase the power right now.
Going to get my car sorted so that it drives well and handles well then I will head down the E85 path.
Radiator, exhaust wrap, muffler and gauges are all going in very soon.
Then I'm going to find time to take it to capital steering so they can tell me what needs upgrading to get it handling like it's on rails.
Ohh and Brakes! they will be added to the list as well as an oil cooler :D
yeah, Rob dont feel bad about not making 200rwks
standard RB25 turbo will never truly make that (for long) the 190-195 is a realistic figure
also we at what 2000ft above sea level.
engines lose ~3% of their power per 1000ft
Also, just because it was a Caltex servo, doesnt mean its Caltex fuel
fouls your plugs mate
If you want some value I recommend Liqui Moly fuel system cleaner
and if you hadn't already done it when you bought the car another Liqui Moly product - at your next oil/oil filter change use Engine Detox (just let it idle - don't boost it !)
Better than any other product on the market - IMHO
Yeah just in case I get SH!T fuel again... Oneshot.
I think? I put some NULON Injector Cleaner through it when I bought the car.
I always put a bottle of NULON E20 Engine Treatment in at every oil change.
(I seem to use Nulon Products alot. :D)
Never used an engine flush etc...
It's also colder the higher you get so surely that evens it all out? :P
Nice work Rob!
Good idea.
Even my 180kw needs more grip, and i thought i had a good suspension setup.
Felt the Power. :woot:
Plugged in my ECUtalk to see that the timing is bang on 5o instead of 150.
When tuning, they had it on 150 but was not happy so did what they could to make it happy.
So 50 and a backed off tune is what resulted. Seems my Timing belt must be out by a tooth or two. :/
All will get fixed and the power will reveal itself. More to come? Yes Please! :D
I think I have heard of people intentionally putting the Exhaust? cam out by a tooth for some sort of gain...
Does anyone know anything about this??
Nah, I just want it to be as it should be, but do people do this tooth skipping thing and is it possible that this was done intentionally for some benefit?
Tried rolling guards, with my DIY tool.
The roller part is not up to it, its too short and when the heatgun is applied, it gets soft and flexes. :/
Or the guards are too stiff, yeah thats it i didnt fk up it was nissan. :P
Cleaning the Volks, not sure whats safe, so using bug and tar remover.
Its safe but not as effective as id like.
Scrubbed till my hands numb, still not clean.
Its the inside of the rim thats so hard to clean, the rest is ok.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
