Nice work Rob!
Bit of a let down with the fact it's not hitting 200kw but not too long and you will be there.
I have decided I'm not going to chase the power right now.
Going to get my car sorted so that it drives well and handles well then I will head down the E85 path.
Radiator, exhaust wrap, muffler and gauges are all going in very soon.
Then I'm going to find time to take it to capital steering so they can tell me what needs upgrading to get it handling like it's on rails.
Ohh and Brakes! they will be added to the list as well as an oil cooler :D
yeah, Rob dont feel bad about not making 200rwks
standard RB25 turbo will never truly make that (for long) the 190-195 is a realistic figure
also we at what 2000ft above sea level.
engines lose ~3% of their power per 1000ft
Also, just because it was a Caltex servo, doesnt mean its Caltex fuel
fouls your plugs mate
If you want some value I recommend Liqui Moly fuel system cleaner
and if you hadn't already done it when you bought the car another Liqui Moly product - at your next oil/oil filter change use Engine Detox (just let it idle - don't boost it !)
Better than any other product on the market - IMHO
Yeah just in case I get SH!T fuel again... Oneshot.
I think? I put some NULON Injector Cleaner through it when I bought the car.
I always put a bottle of NULON E20 Engine Treatment in at every oil change.
(I seem to use Nulon Products alot. :D)
Never used an engine flush etc...
It's also colder the higher you get so surely that evens it all out? :P
Nice work Rob!
Good idea.
Even my 180kw needs more grip, and i thought i had a good suspension setup.
Felt the Power. :woot:
Plugged in my ECUtalk to see that the timing is bang on 5o instead of 150.
When tuning, they had it on 150 but was not happy so did what they could to make it happy.
So 50 and a backed off tune is what resulted. Seems my Timing belt must be out by a tooth or two. :/
All will get fixed and the power will reveal itself. More to come? Yes Please! :D
I think I have heard of people intentionally putting the Exhaust? cam out by a tooth for some sort of gain...
Does anyone know anything about this??
Nah, I just want it to be as it should be, but do people do this tooth skipping thing and is it possible that this was done intentionally for some benefit?
Tried rolling guards, with my DIY tool.
The roller part is not up to it, its too short and when the heatgun is applied, it gets soft and flexes. :/
Or the guards are too stiff, yeah thats it i didnt fk up it was nissan. :P
Cleaning the Volks, not sure whats safe, so using bug and tar remover.
Its safe but not as effective as id like.
Scrubbed till my hands numb, still not clean.
Its the inside of the rim thats so hard to clean, the rest is ok.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
