Meguiars MLS :thumbsup:
Edit:
It's not cheap. Metal Life Saver ($39 ?)
You use a light scourer on/off - wear ruber gloves
Then Polish with metal polish
Comes in a pack with all you need including the MLS and All metal polish, gloves, cloth and scourer/applicator.
..........oh and then go through a Hazchem shower :P
Edited by Sinista32
I think my car is actually slightly quieter now since my Stock Dump came off and the Bellmouth went on.
Having seen that the original gasket was in 2 pieces makes me think I also had an Exhaust leak.
Slight low rev squeal is gone too. hmmmm....
Fixed stereo in Tokyo taxi. Found some wires touching in the boot.
Was making the volume go up/down and front to back by itself. Weird !
Maybe took a corner or two a bit hard - the sub had shifted (found 2 of 4 screws loose on the floor).
oh and just finished fixing toilet leakage/run on :sick:
Edited by Sinista32
Edit:
Instructions say:
Hydrochloric acid, reacts vigorously with alloy. :O
No thanks, it might work well, but one little slip up and ill have stains etched into my polished rim.
Bowdens is working ok but it wont get the stains out.
I realize now that anything strong enough to get those stains off is too dangerous for my liking.
Ill have to use a more mechanical solution: Autosol and wire brush might work.
And ive had to run a file around the back of two rims, to get the dags and sharp edges off.
Yes... taking a hand file to Volks. :devil:
Edited by D.I.Y. Mik
Depending on how vigorous a wire brushing you are planning on doing, go the spinny roundy brush on a drill.
Cleaned up ALL the crap inside of my Rims nicely. (can lend if you don't have) :)
Swapped out my adjustable caster rods and camber arms to replace with stock ones.
Raised car to 110mm at the lowest point for vehicle inspection
smaller exhaust hangers to raise exhaust 5mm
Installed child restraint anchors
Degreased/washed ender side of car
installed OEM looking gear knob
Removed Power FC Hand controller
Removed rear wiper/motor and replaced with MFR delete plug
Hopefully thats everything to pass Dickson
Oooh that looks the goods. ;)
Brushes don't last long do they? Brings back some horrible Wheel cleaning memories...
Reminds me, probably should finish that sometime. :laugh:
found a weird one while searching for a solution
soak aluminium foil in coke or vinegar, and use like sandpaper :huh:
I think the coke is for alloy and vinegar for steel, dunno ill try it and find out.
Theres also clay bar, il give that a go but on the cleaner areas.
It seems theres no clear or anything as polishing compound goes black quickly. Ill have to give it a spray with something to protect it after.
Dropped Rosie off at Dyno Tune to get a 5k service and to fix some light bulbs :D Next stop will be breaks, I'll see how next pay goes.
Edited by RosieR34
I went through the pits at dickson today and i got knocked back due to not having an "engine tune up sticker" also for not having an english owners manual and i need all the japanese stickers replaced with english stickers.
Does anyone know where to get a tyre placard in english for the r32 gtr?
They also asked for me to provide stock track measurements from nissan
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
