Didn't do anything to my car.. But these bad boys arrived. Time to get rid of a little of that wheel arch gap :D
you better get a breaker bar or a tube for leaverage. When i was installing mine i actually almost cried from frustration.
Thanks Brice, will keep that in mind.
Am working straight until Thurs 12 sadly, so will have to stare at them until then :(
on a serious note, give all the necessary points a good spray with wd 40 or equivalent and you will be fine. You will need stepped spanners and or 1/4 ratchet set for rears when you take out the rear seat. pretty easy job on 33
Ok, will do that, and yep, got all chat cheers Patrick.
Hopefully won't take too long.
Unsure about my first guesstimate at ride height though. Trial and error im guessing.
they're set to 350mm eyebrow height approx
q
bro i lift hehe :P
me too lesbefriends Edited by Pattey21
Any recommendation for a decent "skyline" mechanic in ACT?
+++ Trojan. Although it may be a 3 week wait...
Spoke to them this arvo, car will be back to them on the 24th. :(
Is it quieter now? I found after having my Bellmouth installed, things seem quieter and having seen my old turbo to dump gasket in 2 pieces, I'm pretty sure I had an exhaust leak there...
Also I got a cheapy Compression tester in the Post today. That'll be interesting. I Can Lend !!!
Lol same here he told me to give him a few months coz Jake is fixing up his Dyno
I believe the Dyno is getting new rollers.
Whats your car going in for Rob?
Previous SAFC Tune was a little lacking as the Timing was causing issues... Good Chance the Belt is out by a tooth etc...
If so, they will need to get right in there so I may aswell get Waterpump and Belt replaced and Extra Tune for even more WASPZzzz!!! :woot:
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
