After performing some more Temporary Dunwood Mechanics on Jeremy's Rosie34, I installed my New OEM Coilpacks and sanded some paint off in the boot to make my Fuel Pumps Earth Stronger.
If your hubs are slightly out, which is often the case on an older car, your new rotors will be out of line too.
If this happens, get the rotors machined on the hub, mark it so if you ever take it off you can put it on the same way.
Now my rotors are matched to the hubs, as my hubs arent perfect, still quite good but not perfect.
Yes, sometimes you have to machine new rotors!
Made side panels for the radiator intake area.
Just made from corflute for a template, they seem to work ok, bottom is still open, thats next.
Top has the Greddy one on.
Finished installing rotors and got my car ready for dickson and the up coming cruises, fractured my arm and wrist on the bike afterwards so now have to wait 4 months to drive :angry:
Wow, that is seriously unfortunate :(
Had a go at repairing the $25 guards, but i think its a waste of time.
Theres a thin layer of fibreglass in there somewhere under the putty.
And the putty is all old and cracking. ill use them for testing the spraygun.
Bonnett was painted in something that looked like fake vinyl? Thick crap whatever it was.
Couldnt sand it, too soft and clogged the paper, so paint stripper carefully used and washed off.
Then sand sand sand. Getting there. The primer underneath is nice and hard.
And some freebies came with a book i bought.
I dont have an rc car, so there free to whoever wants them.
More things in the mail: :D
Bits for wheels and deep dish for correct position when the race seat is in.
No fake centrecaps to be found, so i had to fork out for the real ones. >_<
No rear tyres yet, i have to wait. So sunday hillclimbs on the street wheels/tyres.
Now i have a guide to handling, i was thinking i should try a suspension tweak to try and get less drift.
This Sunday?
Dayum! I would come n watch again but Pie Cruise. :(
why do people ditch turbo timers these days. i realised they have been associated with the fag hectic factor but thats not what they were made for. I reckon they keep your turbo well specially if your in a rush.
If not for the DEFECT factor I would have left it for the odd occasion where it would be useful.
But even in a hurry I'm not going to be boosting all the way up the street into the driveway.
I don't think they were made for road cars, hectic factor just took them there.
besides, if I go for a track day or something I can easily reconnect it.
1. Illegal ! (no one in control of the running vehicle)
A vehicle sitting stationary with the engine running (Idle) get's warmer and stays warmer for longer. Although does cool your Turbo due to oil and water still circulating.
It's better 2 minutes out to drive pedestrian and let it cool down. Forced airflow continues where as when stationary ....
Like athletes - warm up and cool down. It will prolong the life of ALL your vehicles major organs.
Turbo timer is good as it circulates the oil and water to the Turbo if you seriously don't have time and drive it VERY HARD (Race conditions) right up to your destination and then shut it off immediately.
Turbo's start glowing between 350 to 500 degree's. If it's not glowing then your probably ok
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
