. But still I don't go out to do skids.. I polish and buff it. And drive it carefully because I can't afford to repair it.
Made my self cry... :'(
Ouch man,, hate when things like this happen. =(
  • Like 1
Got the toe sorted; front was 0 now 3mm in, back left was 3mm in, back right 1mm in, now 0-0.
Camber next; front is 0-0 rear is -0.4 L, -0.7 R. going to -1.5 front and -1 rear.
Youtube taught me this trick..... get a bucket full of water, clear tubing, tape the tubing to a ruler, suck the water into the tubing to measure the relative height of where the wheels go with the water level, then level them off with hard vynil tiles.
post-89755-0-59175400-1385118956_thumb.jpg post-89755-0-98338300-1385118984_thumb.jpg
Perfectly level to the mm. A stringline carefully set up to measure toe. A handy tool from Aldi for camber (way cheaper than a camber gauge).
And get a pro to do the job.... :D
post-89755-0-41381200-1385119030_thumb.jpg post-89755-0-86819900-1385119069_thumb.jpg post-89755-0-91255500-1385119090_thumb.jpg
  • Like 2
\m/ Anthrax Rocks! \m/
I hope you pay that Pro well Mik. That's a fine job indeed.
That's just crazy stuff that I never would've even considered. :laugh:
Cool.
Aaahhhh.. im not that clever as it turn out. >_<
I forgot that when i change camber it will change toe a little, and the adjustable upper arms on the front are well tucked up in there. Impossible to get at.
So jack it up, take the wheel off, adjust, wheel on, back down, measure, back up, wheel off..... etc
Anyway ill get there eventually, at least the rear is easy to get to.
Finally!.... fiddly sht sorted.
Got the front arms all the way in and can only get -1.2 degrees camber. 3mm toe in.
Back is at -0.9 camber. 0 toe.
Edited by D.I.Y. Mik
Put $20 of Fuel in, Checked Tyre Pressure, Washed it, Checked Radiator, Oils, Air Filter, Removed Hub Caps and Rego Sticker.
On What Car?
This.
Bought it! :D
Love it.
  • Like 2
On What Car?
This.
Bought it! :D
Love it.
Aha! Awesome! :yes:
So which one is the track car?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
