hell yea!!! first try?
Nah 4th time lucky. Well I went there 3 times in one day, the kept winging about the exhaust height. I couldn't do it properly on Monday, so got a big ol' hammer and bashed it flat. They really didn't like that, so yeah don't do that.
Ended up having to re weld the back half of the pipe, they were happy after that. One dude there seemed to think that I had put restricter plates in the exhaust, because having a 3" pipe go into a tiny pee shooter muffler does nothing to make it quiet (Idiots, goes to show how much they actually know). Another guy asked me if it did have the plate, I went full retard and gave him a blank look and said I don't know what a restricter plate is. So that seemed to work, they stamped the paperwork and I was on my way!
Edited by dirtywan
Order More Braided lines. I've got sooo many parts on the way now. Though i think the size i ordered for the catch can will be too small. We will find out.
Finally got my car past the pits this afternoon.
Now to put adjustable arms back on and get an alignment (where is capable of aligning fairly low cars?)
Good stuff! Try the guys are capital steering, they are great. Also I'll have to drop your owners manual past at some point.
What did i do to my car today.............
Gutter rash on the Volks. >_<
NOOoooo!!! That sux. :(
Well I just drove mine (33) to the Servo, Filled up and checked tyre pressure.
First time I've driven it since the weekend. Wow!
Jeremy, if you think you need 250kw to Enjoy, try driving something lesser for a week. It's all Relative.
Manual is weird. :D Suspension Feels like it's worth Thousands, Brakes are Awesome and Power is :woot:
Still... I love Both the lines as they have VERY different Characters.
  • Like 1
Finally gave the 33 the Vac it has been needing for Oh So Long...
Can't have Mum 'n' Dad covered from head to toe in MDF dust now can we? :laugh:
hmmmm... I wonder if they've ever been from 0 to 100 in 6 seconds?
Looking forward to the Drive to Orange and back. :D
Must check fluids etc... Consider it done also.
  • Like 1
fitted a high flow, injectors, ecu and tapped a thread for the MAP sensor and IAT sensor and took it for a tune. Hopefully all goes well over there. Hate the feeling that something wont go as planned.
  • Like 1
f**k!! I thought it was bad getting gutter rash on mine... id kill someone if it happened to my volks (if I could afford them :( )
With all those stock parts in I was running like 150kw haha got my power back and was like YEAHHHHHHH. But no job - no 250kw
I have some volks from 97 or 98 that came with my car, looks like ray Charles tried to parallel park it. Now I have the lmgt4's I think ill fix them up and paint them a stupid colour.
Looked at my door because it is very loose even when closed. Found it keeps the interior light on so I got out some sticky tape and made sure the door light thing is kept pushed in haha
Not sure how to fix the door, it seems to be sagging from the hinge :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
