Got the vb running. ..it then preceded to overheat in 60 secs. Blow the cap off and shower me in boiling liquid.
Then it caught fire...
Any one want a slightly singed 1979 commodore?
Insure it.
Wait a week
Start it up again.
Profit?
Insure it.
Wait a week
Start it up again.
Profit?
I know a family who's lawn mower burnt and they claimed on Household insurance (paid).
It burnt twice more with friends and insurance paid out on all occassions
Pulled off the Drivers door trim in an attempt to stop randomly being locked out. (Have to unlock from passengers side sometimes.) :(
also turned the window winder handle 1800 to stop it digging into my leg.
Tightened a couple of things inside to stop some rattles. (Harder springs bring the noise.)
Removed some old Maccas fries from under the center console. :yucky:
Drivers side rear tyre seems to lose approx 8psi / day. Must get it fixed.
Took the dog for a drive to the servo for tyre inflation.
SkyWagon Wedge. ;)
Yesterday I filled the Tank with Shell 91 :O
I've put 98 in it too. It's just nice to not have to worry about the good stuff for a change. :D
Also, I Just Won a Set of Lukey Extractors on Ebay! :woot:
  • Like 1
polished my rocker covers, pic doesn't do it justice :(
dont mind my bush mechanic side with the oil breather ;)
Edited by ..::R33GTS-T::..
nice mongoose alarm
haha thanks! how did you notice it ?
its starting to f**k with me .... it went off when I was driving it the other day, water got to it when I was washing the engine bay.. its all good now tho :)
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
