Got the good soda blasting media. Now it works much better, i can control it.
It can be used to remove paint and not damage rubber, if its on low pressure and you use it carefully.
Taking paint off plastic without damage is much harder to do, if not near impossible. But you can carefully remove a layer at a time, leaving some primer over the plastic.
Because the new soda flows much better, i can turn the pressure right down (35psi) and it still works. This gives the control needed to clean those bits carefully.
Also theres a lot of work just to clean up and make sure the "skyline" in the rear bar is straight and neat, (how the fk am i going to buff the clear in there?) i might just fill it. Dont really like that kind of thing anyway. Little detail bits and grooves etc, just trap dirt and wax/polish, and only look good if they are all perfectly aligned and stuff. I think ill fill the grooves in the tail light surrounds for the same reasons.
Thinking about how the skirts and pods are just glued to the side of the car. I hate how sht that is and i might rivet or screw them on tight so theres no gap.
Installed a Bosch 040 today, cheers Mik!
What a bitch of a job.. Think next time I have to change a fuel pump im taking it to a shop.. So fiddly in such a confined space.. :angry:
LOL! Sux Dunnit? Loved getting high on fumes, the bruises and the stingy cuts on the arms when I did my 044.
I just bought a Walbro GSS342... Fun will begin again. :wacko:
funny all that talk on fuel pumps :yes: must be that time of year ...
Walbro 450 ltr/ph, E85 compatible put in today, and only $200 for the pump and kit, cheering !
Fuel pressure gage next. Will make my life easier when doubting the fuel pressure being delivered.
Don't track as you know so Will wait a little while before cooler goes in. Was just hedging bets with this one. May go E85 soon.
Part of the reason I'm changing from Bosch 044 to Walbro GSS342 is the noise I get when the Fuel gets hot as I obviously don't Burn Enough of it.
Dark car, Hot Day, High Flow Rate Bosch = Buzzy Buzzy Bee.
Hopefully the Walbro is a little quieter in the same circumstances.
044 has only done around 10,000ks... Anyone wanna buy it? :D
I had bought a Nismo and handed it to a shop to install.
But looking at it after removing - it has no markings or indication of what sort of pump it is.
So the Nismo may have ended up somewhere with someone else. Too long ago to worry about.
Was noisy priming and when hot ran on, so may also have been a Bosch 044 - was time to go anyway.
Ps. I like your sig pic Rob.
Edited by Sinista32
Deatchwerks are the go for a painless fuel pump install. And they arent loud.
They fit exactly in the cradle and the wires are real good.
Just unsolder the old ones off the tank lid and solder the new ones on. They have the fuel proof insulation and a plug to go in the pump.
That company is cool as they make upgrade bits to fit like oem bits.
Agreed on the DW fuel pumps, a lot quieter than the walbro's..
Today finally got my front fender braces installed after shearing one of the nuts last weekend. Also installed TRD swaybar bushes, so they actually match my swaybars now. On the lookout for a new intercooler...
Edited by Scar
Would like to know what kind of cooler you decided on.
You always do a lot of good research on these things.
No real idea yet Mik. See what happens, if anything.
Ideally a CO2 system :D.
Seems to be a number of systems but Cryo is in my opinion best.
Edited by Sinista32
Some serious gear. Would suit the Sinista. :thumbsup:
Thats the system i can find i think your talking about. I like the air chillers, what a cool idea. And how the leftover gas cools the intercooler is neat.
The others are return line fuel coolers and water/meth injection. Which keep temps under control, but not actually chilling it.
I cant find anything about how long a bottle will last on the CryO2 system, but there is the throttle switch option, which would save heaps of gas.
Seems to be more of a safety for the engine and a small power gain. Worth it for a well built RB26 $$$$$
On a 40 degree day this would be real peace of mind. And would out perform any other turbo car.
You could have a bit of fun with that... put a Nos cover on the bottle and have a purge line.... "Yeah man i got nitrous" :laugh:
Its a modular system, so you get the bits you want.
http://www.designengineering.com/catalog/cryo2-system-components
almost eveywhere else is cheaper, ebay, summit etc, dunno why.
Got Straight home from work and swapped back in my old rear Pedders shocks but with the NISMO springs on. (on the 33)
Passengers rear was leaking and starting to knock and wobble. :verymad:
2 rear shocks with spring change in an hour... Not bad? I think it took an hour and a half last time not including seat removal. :D
Also received an R31 one piece tailshaft in the post. (E-go) overnite from Melbourne. (less than 15 hours after paying for it) :woot:
Now to install...
Nice one Juan. ;)
I noticed a big difference when I put my RDA rotors on the 33 a couple of years ago too.
reminds me... gotta do brake fluid in the Wagz.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
