How does a well maintained, Fresh (7000km) old Engine crapout in such a big way under normal driving conditions?
Scarey.
It will be interesting to find out just what's up.
Big single while its out ;)
NTY i like my twins.
TL;DR
I didn't run it much after hearing the knocking. Adrian just had a look at it seems to have gone after 5-10 minutes worth of running. Either way it will get towed in tomorrow. Incoming new Koyorad Radiator (Kyle, AC gear? =) i mentioned to Adrian you had some) and a few other bits and pieces. So it seems everything MIGHT be ok. But i won't hold my breath.
Fitted the drivers side control finally
Started removing side skirts, I have a set of standard GTR ones coming
This little screw was inside the back of the door jam
Now for the removal and to look at all the gunge lol
post-40722-0-13800000-1396142825_thumb.jpgpost-40722-0-48151400-1396142840_thumb.jpgpost-40722-0-65995000-1396142851_thumb.jpg
I'm very excited to see no bodgy repairs done to the side. I have seen some build threads where they weren't so lucky.
It's amazing how much crud can build up under things.
Was very similar in under the rear bar of the Wagz.
Despite plenty of stuff I need to do to the 2 lines, today using some radiator hose, a hose clamp and the lid off a tin of corn, I made a plate for behind the steering wheel so the horn on the Wagz will work with the R34 wheel. (previous effort worked untill I turned the wheel) :laugh:
  • Like 1
Haha engineering at its best :)
Its pretty filthy but cleaned of pretty easily, I'm going to get a pressure pack made up and touch it all up if the rain holds out next week, fingers crossed.
I got the passenger side off, the sikaflex was it better condition so it was a little more painful. I couldn't get the passenger side control arm on before the rain hit though :(
Capital Auto Paints in Fyshwick are Great for making up colour code matched Spraycans! I have and do recommend. :thumbsup:
It's always intrigued me that Skylines have a pair of Feeble, Anemic little horns.
I replaced the 33 horns ages ago to something a little beefier. (cheapo pair off Ebay) but still better.
It seems the R31 only has one little weak sauce horn!
Well not anymore! Hahaha... This arvo I wired in my old R33 pair, the original R31 and another I had spare.
Might still be Weak but now there's 4 of them! :laugh:
  • Like 1
Thanks for that :)
I have always used the autobahn jobbies, but only ever got metallic. The first can was great, the nozzle sprayed beautifully, the second can (months and months later) was terrible. The colour was good but sprayed like white. I swapped the nozzels and then it was sweet.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
