Sanded half the car again today as i used a dodgy bit of sandpaper yesterday and scratched it all up. >_<
Making a few mistakes then fixing it up makes it take a while, but im learning from each fk up.
I think i have the spraygun sorted out, but ill do final tests to make sure.
So finally now its all smooth, clean and wrapped up ready for a sunny day to put on the final coats.
Making a cattle grid type thing to take the dip out of my garage entrance, so the car can go over, but still have the water drain away.
I'll take some pic's tonight for you - can you PM me a mobile number or email address so I can sms through to you.
Done, thanks!
I'll need to measure it up pretty well in person to be able to cut it to the correct shape.
Need to see if it's the right shape in terms of how my fuel system is set up and where my battery sits first. But will organise to borrow and get one to you once I know! :)
Looks Awesome Andrew! ^^^ Guessing this is the Soarer yeah?
Created some Clear Front Indicators for the SkyWagz cut from a Fluro Light cover as is the R31 way.
They're actually just attached ontop of the original orange lenses. (no need for orange bulbs) ;)
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
