New front bar installed, unfortunately I found out the blinkers don't fit AFTER putting it all back together.
I'll need to source some S2 blinkers to install and solder on.
This required a whole new S2 reo to be installed and headlight brackets, took me the whole afternoon.
Also put the front set of mudflaps on the car, I'll put the back ones on later.
  • Like 3
Yeah a little louder, not sure if it's quite whoosh whoosh gangsta though. The stock box actually isn't all that bad once you remove the blocking plate on the passenger guard side.
Edited by cpark
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
