Haha, it really is.. Just minus 2 doors :yes:
But, im not doing that crazy setup you have with switches and using the solenoids etc. Although it sounds mad, I don't think I can do it. I remember my head hurting as you were explaining it :ermm:
I don't use that anymore since I got the R32 Actuator...but I still have on the shelf, My Mad DIY twin Solenoids... Plug & Play...If you wanna try it. :thumbsup:
Have to have the R33 Actuator on though.
Edit* The head Hurting thing is just me...:unsure:
Started the R33 for the first time in 2 months... I nearly cried cos I miss driving it.... God damn back issues stopping me from driving it.
mine last ran july.
ill drive yours for you.
mine last ran july.
If you want to get a blue slip done and put rego on it go for it lol...
pulsar and/or donty, or anyone i guess =)
R32 actuator on R33.. is it a simple straight swap? would i need to remove/replace solenoid or anything else?
I was thinking about doing it but went with a boost tee for now but still might go for that option.
car is mostly stock..
Straight Swap, remove the solenoid, block the hose going back into the BOV return pipe. Happy Dayz.
  • Like 1
A victory in the war with perspex, the second operation was successful.
After strategic use of the texta and ruler, the heatgun softened up the enemy before an assault with snips to finish it off.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
